Science & Laboratory Logo
Question about National Optical Science & Laboratory
Serial number I am looking for the serial number for a National Microscope Model 139.
Posted by Kristi Scott on
  • Marvin
    Marvin Sep 02, 2016
    Hi
    We would not have that info.
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: 6V 20W transformer needs to be replaced
Dear sir,
r u sure that get open then try to replace with same rating, if this kind of transformer is not availabale
try to rewind it. with help of expert..
for any quary you can contact any time.
Posted on Nov 24, 2008
Anonymous
  • 45 Answers
SOURCE: single ocular microscope serial no. 901337, no
Any hardware store should have one that works.
Posted on Dec 07, 2009
Anonymous
  • 10865 Answers
SOURCE: Find serial and model number
Hello. for a top loader look here
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
  • Posted on Apr 30, 2010
    Anonymous
    • 5911 Answers
    SOURCE: model and serial number
    If this is a Whirlpool manufactured TOP LOADER (such as the one you posted this question under), the model number and serial number are located on a nameplate along the wash tub rim under the lid.
    If this is a FRONT LOADER, the model number and serial number will be located along the door facing as you open the door.
    If you have questions, please post back and let me know. I hope this helps you.
    Posted on May 15, 2010
    Anonymous
    • 267 Answers
    SOURCE: serial number problems 1t0-003815
    It is a YZ80D 1977...first link below is a Yamaha VIN cross reference if you want to verify. (a lot of scrolling)
    As your VIN is only 9 digits, this indicates a pre 1982, when a universal 13 digit VIN was adopted, then soon after our current 17 digit VIN.
    (please note: I'm assuming the VIN is from the plate on frame and not the crankcase serial number as engines are easily swapped)
    Second link appeared amongst a search and indicates a 1992 model. This may be the basis of the problem your encountering.
    Third link is a Yamaha decoder I've used successfully (17#) try it or check the Yamaha Corp. link therein.
    Cheers.
    http://www.johnnystoybox.com/yamaha_parts_cross-reference.htm
    http://www.boats.net/parts/search/Yamaha/Motorcycle/1992/YZ80D/parts.html
    http://www.motoverse.com/tools/vin/yamaha.asp
    Posted on May 18, 2010
    2answers
    Bicycle serial number Want to know make and model of my bicycle the serisl number is ESW7R0725 60312
    Sorry, comprehensive databases for bicycle serial numbers do not exist.
    Sep 20, 2014 • Cycling
    Transfering number
    you must contact your cell phone service provider and tell them you are transferring your service to a new phone
    I am looking for a Sewing Machine Manuel for a Sears Roebuck
    Do you have a model number? That looks like a serial number.
    Pre 1955 machines were made by companies like National Sewing Machine company. After that they were made in Japan. So maybe to help us out... you can post a picture of your machine?
    1helpful
    I need a replacement for a Lift-Master 1/2 HP garage door opener. I can't find a model number, but do have a serial number: 41A4252-7B. It was installed in 1995, but I have no original papers on it. Is it...
    The number you give is a part number for the logic board. The model number is on the opposite end of the opener. If it is a Craftsman the model number will start with 139.
    I have inherited a Nikon 83988 microscope with a transformer. I know nothing about this; I have no manual. I think there may be bits missing (there is no lamp for example). When I plug in the...
    I think the number you gave is the microscope serial number, to hope to get help you need to find the model number so people can help. At least post a picture. In general the microscope needs a light source to be bright enough to use. The transformer is meant to provide power to the light. If you use the microscope with a light shining through the object held by a glass slide then the light is below the stage which holds the object. Sometimes on simpler microscopes they have a mirror below the stage and you shine a bright light beam into the mirror and must adjust the angle to reflect the light through the slide. In more complex systems the light is built into the microscope. For opaque objects you must shine the light from above onto the object. If you can't find the official Nikon light source to connect to the transformer, you may be able to get non Nikon light sources. For my stereo microscope for example, I use a LED ring-light I bought on ebay for ~$25. This lights the objects from above and fits around the microscope tube just above the stage.
    My heat resistant glass panel broke. I need measurements.
    no you need make model serial number then look on line at national energy for the parts, the numbers make etc are on the heater
    Dear sir,
    Top National Optical Science & Laboratory Experts
    Tom Chichester
    Don A
    Don A
    ADMIN Andrew
    ADMIN Andrew
    Are you a National Optical Science and Laboratory Expert? Answer questions, earn points and help others
