Question about Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter
Gogo ultra 4 wheel... 6 beeps but throtle is straight and we have turned it on and off. Works one day but not the next . How do we reset it.
Posted by Roy stone on
medypharma2148
    Sergeant:
    New Friend:
  • Pride Mobili... Expert
  • 176 Answers
Buy zoldria 4mg price Injection is used to treat or prevent osteoporosis in women. Buy zoldria 4mg injection is manufactured by Cipla Inc. Zoldria injection is contains of Zoledronic Acid. Zoledronic Acid cipla. Zoledronic Acid injection Dosage.
Posted on Feb 14, 2019
Jeff Bird
  • Pride Mobili... Master
  • 1,346 Answers
Hi 6 -beeps possible faulty potentiometer speed pot.....cheers
Posted on Sep 04, 2016
Wts gogo scooter just keeps beeping whenu switch it on whats that mean
this could mean the scooter is not in drive try the free wheel lever first.
Feb 25, 2015 | Pride Mobility Products GoGo Elite...
Beep codes beeps
Contact a local DME dealer in your area or, on the internet. Give them your serial number for the GOGO to order a new solenoid brake. It is important to have your serial number when ordering to ensure you get the correct part.
Jun 07, 2014 | Pride Mobility Products GoGo Elite...
Scooter beeps but will not go
Make sure it is placed in gear, sounds like it is in the Neutral free wheel position.
If the scooter moves easy when you push it, it's just in free wheel.
Feb 13, 2014 | Pride Mobility Products GoGo Ultra X...
Gogo ultra beeps and shuts down. let it sit for a while and it will restart
a couple of things could cause this. A weak battery is one, the other would be excessive load on the motor, operator past the recommended weight limit, thick carpet or grass, gravel ect. can all cause the unit to work and cause a thermal shut down.
So first have the batteries load tested.
Hope this helps.
Feb 05, 2014 | Pride Mobility Products Go-Go Elite...
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
I have bought a go go scooter which does not have a manual
evilyn Goto pridemobility.com click on scooters then find the picture for GoGo Ultra click on the picture and on that page on the right you will find owners manual click on that and download your manual Hope this helps you
Sep 19, 2010 | Activeforever Pride GoGo Ultra 4 Wheel...
Beeps when in drive won't move
How many times does it beep or is it continuous? Should beep a few times (usually up to 9 times), then stop, then beep so many times again, then stop and so an and so forth. Most of the time this is caused by the scooter being in freewheel or THINKING its in freewheel which could be a faulty brake switch. Also, on the GoGo ultra, the battery contacts regularly cause this problem and have to be replaced. They should be splotlessly clean and shiny for the contact to be good.
Feb 15, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My gogo-ultra will not run. it has been stored
hi,
Check the connections between the battery and motor, if the rear come apart check there connections there,
If the connection with the batteries string loaded, rough them up slighty with a wire brush but be gentle and is there freewheel lever right in position for drive.
Regards
GeWiz.
Oct 24, 2009 | Pride Mobility Products Go Go Ultra X 4...
PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Jun 10, 2009 | Pride Mobility Products Go-Go Elite...
Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter Logo
357 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
