It can be the touch pad.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
SOURCE: LG Intellowave
If it's made for (or safe for) microwave ovens it should work in any of them, and I would just follow the steamer's instructions.
Does that answer your question or do I misunderstand the situation?
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: My LG Intellowave still has
Microwave ovens use a series of micro switches to operate as interlocks to ensure the unit will only operate once the door is securely closed.
If these locks are not operating properly, the timer would count down just like it was operating. There will be no noise like the normal vibration or fan sounds when the start button was pressed. It will simply act like it will operate, but it will never turn on any of the components.
You would need to check these switches if they are functioning properly and would need the help of a qualified technician to test them. If you plan to do it yourself, Check if the switches are mechanically operating and that electrical continuity would change as it was actuated.
There are a total of three switches normally, one for the door and the other two for the high power.
Hope this helps.
SOURCE: LG touchpad doesn't work
use the common sense,logically, fix it. God bless you
a stuck key or non-responsive key, most of the time you will have to
replace the keypad for this microwave oven repair. If your keypad is
connected to your control board by a flat ribbon wire, try disconnecting
it and clean the silver contacts with an ordinary pencil eraser. After
cleaning, plug it back in and try it. If it doesn't fix it, replace
the keypad unit. Some units actually have keypad tests to confirm your
diagnosis of a bad key.If your keypad and control is the same
unit, replace that unit. Another note, unlike stove/oven keypads and
controls, most microwaves do not have error codes or tests to
distinguish whether it is truely the keypad or control. Most of the
time, it is the keypad that needs replacing, but a small percentage of
the time it can be the control. Check the tech sheet if they can point
you to the right part.
SOURCE: Glass plate replacement for my LG intellowave
NEED PLATE REPLACEMENT FOR MY LG INTELLOWAVE. WHERE CAN I ORDER ONE AND PRICE PLEASE
