Here is the Owner's Manual for the KLH GFX550 https://www.dropbox.com/s/bqr689il4liw77...Here is the Owner's Manual for the KLH GFX550
https://www.dropbox.com/s/bqr689il4liw774/KLH%20GFX550%20Subwoofer%20Owners%20Manual.pdf?dl=0
You can't post conmments that contain an email address.
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
Yes, the 10-120 can use a L & R low level subwoofer input. You can get a short 6" RCA splitter adapter from Radio Shack for a under $10. (1 female input, 2 male outputs) Alternately, just plug the subwoofer output on your receiver to just the low level R channel on the KLH sub.
I wrote to KLH and they sent me the schematics for the upper and lower boards. I asked if I could share them, and they gave me permission to post them for use here.
Unfortunatly it is due to the wiring within the house. Short of buying an apc back up which will regulate the power there is not a powerstrip that will stop this. I used to have the same problem
