Question about Sony Televison & Video
I need to reset lamp timer on my Sony KDS-R70XBR2. There is no pip button or split button on my remote rm-y1105 is there another name for the pip button. There is a reset button next to the sleep tm
Posted by Mark Lucia on
Marvin
    Top Expert:
  • Sony Master
  • 85,239 Answers
PIP is the standard nomenclature for all makes.
Posted on Aug 30, 2016
5 Related Answers
Anonymous
SOURCE: pip pictture doesn t turn off
I had the same problem many times, and I don't have the original remote. Go into your menu options and select Auto-Program. It will run through all your channels, but when it is done, PIP will be off !! I have PIP!
Posted on May 21, 2009
Anonymous
SOURCE: reset lamp counter on PT-52LCX66/PT
i aswell dont have PIP on remote but i found another way to fix....
hold the volume button ON TV - down and the 0 zero button on remote at same time :) just worked for me...
Posted on Jul 29, 2009
Anonymous
  • 10 Answers
SOURCE: i dont have a pip button on my remote to reset my
if you do not have the (PIP) button on your remote look for for the (split) button and try the volume down and (PIP/split) trick again. it worked for me!! good luck..
Posted on Oct 08, 2009
Jaime Hernandez
  • 2337 Answers
SOURCE: RESET LAMP HOURS ON SONY KDS-R50XBR1 sxrd tv
Click here to download the user'e guide and go to page #113 to reset the TV to factory settings.
Posted on Feb 27, 2010
Anonymous
  • 10594 Answers
SOURCE: I CHANGE THE LAMP ON MY SONY TV.A MESSAGE COME ON
Press HOME button on remote, select SETTING icon then go to GENERAL settings, you will see Lamp Replacement option, select it and follow the steps on screen to reset lamp timer in Sony KDS-50A3000
Click Sony Support to download user manual copy, if required.
Hope this will help you.
Thanks.
Posted on Nov 29, 2010
Reset lamp timer
Simple answer: -vol button on set and split button on remote hold at the same time
I just figured mine out!!!! So many people with so many different solutions. I read the instructions for the TV, those says to read the instructions for the lamp. I read the instructions for the lamp but this model isn't on the instruction list. For other models it says to use the volume down button on the set and the PIP on the remote. No PIP button on the remote. But wait the bottom row of buttons has a multifunction button for split screen! I tried that and it worked. I had a message that said the lamp timer was set to zero. Done! Hope this helps someone out there.
tip
How to reset the lamp timer for Panasonic DLP TVs.
When you replace the lamp on a Panasonic DLP or LCD TV you will need to reset the lamp timer to zero for the TV to reset the lamp timer and extinguish the change lamp indicator.
There are two methods used depending on which model TV you have. The older units use the first method and newer units use the second method. You can tell which method you need to use by whether you have a PIP and/or SPLIT button on your remote. If you have them use the first method, if you don't use the second method.
Method number 1 (for older units):
Follow the procedure below. You use either PIP or SPLIT button depending on whether your remote has SPLIT or not. Some do not.
Perform lamp timer reset only when the lamp has been replaced. The idea is to know when to replace the lamp before the end of it's life when it could explode or short out causing a hazadous condition. If you reset the lamp circuit at any other time the replace lamp warning will not come on at the recommended interval.
Be sure the power cord is plugged into a properly grounded wall outlet.
Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the
PIP or SPLIT button on the remote control at same time for more than 5 seconds.
If your remote does not have a split button you use PIP, if it has a split button, you would use SPLIT.
When reset procedure is complete, the screen on the TV will indicate that the lamp has been reset. When lamp time reset is finished, the LAMP indicator goes out.
Method number 2 (for newer units):
Press volume down on the TV and the zero button on the remote at the same time for longer than 5 seconds and it will reset the lamp to zero.
These procedures should reset your lamp timer and you will be good until the current lamp fails or the change lamp indicator illuminates again signalling that it is time to replace the lamp. Three to six years on average depending on how much you run the unit per day. Do not ignore the indicator. Change the lamp immediately to avoid further damage and expense or worse.
Thanks for using FixYa and for the great rating.
hardrocko
on Apr 11, 2010 • Televison & Video
Change power switch to kds-r70xbr2 70 in. tv
Call Sony for a part number and price---I have not seen a manual power switch fail on any of these AND even if it was bad the remote should still work
what is set doing or not doing?
4helpful
I CHANGE THE LAMP ON MY SONY TV.A MESSAGE COME ON EVERY TIME I TURN IT ON.HAVE TO RESET THE TIMER, BUT DON"T KNOW HOW.SONY MODEL NO.KDS-5A3000
Thanks.
6helpful
Ineed to reset the lamp timer on my panasonic pt-56dlx75-k tv I installed a new lamp
terryc43,
This should solve your problem.
1. Turn on the television.
2. Press the down button on the TV Display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating!!
hardrocko
MY PANASONIC PT-52LCX35 REMOTE DOES NOT HAVE A SPLIT OR PIP BUTTON. MY BOTTOM BUTTONS ARE TV/VCR, VCR/DBS CH UP,DOWN. HOW DO I RESET THE LAMP TIMER. THIS IS THE REMOTE THAT CAME WITH THE TV.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. The buttons used are the TV's volume down and the remote's number 0, not the 'split' or pip for your model.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
6helpful
I dont have a pip button on my remote to reset my
Red led blinks 5 times.
The lamp driver ( Ballast) is faulty
5helpful
3answers
Lamp Timer Reset procedure Panasonic Projector PT-L759E
Greetings!
It's been a while since I did one of these, but if I remember correctly:
- Turn on the set
- Push volume down on remote and at the same time....
- Push Split on the remote and hold both for 5 seconds
This should do it. The display should reset to "0".
Rob
21helpful
2answers
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Televison & Video Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
