SOURCE: HP PSC 1616 All-in-one
Prints red only including direct from printer -no computer linkage that right? or vis the computer. If it is the first situation then pack it up take it back. If it prints OK on its own but off via the computer -come back
SOURCE: Printer/Paper Jam Brother MFC
Well I fixed it!!! Here's what I did. You see this picture of the cover opened? Where the arrow's pointing is the home position of the printer head. Under there I found a scrap piece of paper! Here's exactly what I did. When I got home I decided to plug it in to see if it would work, but it made the same noise and showed the same error message as before. I opened the cover as shown above. This resets it, and it says "close cover". I closed it, and AS it started to go through its routine I OPENED IT again, and I could see the printer head moving back and forth. At this point I used a flashlight to see where the home position of the Head was, and that's where I found the scrap of paper!
I unplugged it for safety and was able to remove the scrap with my fingers.
By your descriptions, referring to the other users, you just might have the same problem.
SOURCE: HL-2030 printer won`t print labels with Word 2007
If it's the same as my Hl-5250DN, you have to use MP Tray mode. The MP (multi-purpose) tray is cleverly hidden on the front of my printer.
SOURCE: I can not seem to print my 4x6 on the glossy paper that i have
Run a free scan for all outdated drivers( included HP drivers)
HP Photosmart C6280 All-in-One Full Feature Software/Driver 9.7.1 Mac OS X v10.3.9/v10.4/v10.5 was presented for free download to install, add, update, setup HP Multifunction. please check your digital device manufacturer HP, device category Multifunction, device model, operating system, driver version according to HP Photosmart C6280 All-in-One Full Feature Software/Driver 9.7.1 Mac OS X v10.3.9/v10.4/v10.5.
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
