Hello, I have a problem with my Marine Radio FUSION ms-av700, this one didn't read the CD. I have cleaned the laser head and nothing change. The screen sad than the CD is downloading but the disc didn't turn. Do you think it could be repair
SOURCE: I recently installed a new marine stereo Fusion
Hi! Usually the error 2 from the fusion means that the cd has scratches or the cd is unreadable. By then it will stop and will display the error. One thing that can cause this is if the optical lens is dirty so I strongly suggest that you run a cd lens cleaner then insert a disc that is free from scratches. This will resolve the problem. Hope this helps and thank you for using FixYa!
SOURCE: Hi,\r\nI recently installed a new Fusion MS-CD60
As the Radio and Aux works fine the problem may be with the motor inside the equipment which is not rotating the disc.Only when it rotates the lens will read the content in the CD.Please take your fusion.If the motor rotates then the problem is with the lens.Try using lens cleaners and if the problem still persists then give for service as this cannot be done by you.This requires a experienced hands.
Thank You
Thanks a lot Tom.
Don't you have an idea about somethink i can do to repair?
see you
Rudi
