I have checked the debris filter and it is clean. I have accessed the drain pump and it was clean. What else can I do to fix the problem? I first had a problem with this machine about six months ago when it left the washing still fairly wet after the final spin. The same problem happened about two weeks ago. Now the machine won't drain or spin with clothes in it or not.
I checked the hose from the bottom of the drum to the drain pump and the hose on the other side of the drain pump and didn't find any blockage, so I bit the bullet and purchased a new drain pump for A$24.90 (delivered in a week). I have just fitted it and ran the washing machine on rinse and spin without any clothes in it and it worked just fine. Problem solved! I do hope this solution helps others with the same problem I had.
