Question about Connex Radio Communications
Have a connex 3300 and cant change band to def but can works on abc how do u get to def bands
Posted by William Wiltrout on
Mike Charette
    Genius:
  • Connex Master
  • 1,847 Answers
First of all if you do not have a ham license then you should even worry about getting on any band other than the AM band .
Posted on Sep 03, 2016
5 Related Answers
Anonymous
SOURCE: setting 3300 to basic cb oper.
On the 3300hp use band switch at position A band switch to hi
Posted on Jan 25, 2008
Anonymous
  • 126 Answers
SOURCE: Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
ozark333
Joe A
  • 396 Answers
SOURCE: On the Connex CX-3300HP what is the Band knob for.
The Band knob moves the frequency coverage from 25.615 and 28.305
The Hi-Low switch determines the lowest frequencies and highest.
Here is your owners manual.
Posted on Sep 29, 2009
Anonymous
  • 5 Answers
SOURCE: just installed a connex cx 3300hp not sure of
it should be am selector switch on d/a and hi band
Posted on Jul 26, 2010
Anonymous
SOURCE: Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Posted on Sep 05, 2010
2answers
What channels are legal to use on a Connex 3300 with 40 upper, lower and regular settings?
only the CB band to TX on.. you may RX on any frequency.
ch.1-ch.40 am and SSB if it had it.. are the FCC allowed channels. yes there are people on those other bands. user beware.
My connex 3300 wont transmit anymore and the talk back wont work either,i have tried a different mike and when you key it up the meter still won't swing.
Plug in an external speaker to the pa jack ... Switch the band selector to pa and see if you hear yourself... No? Bad audio chip
I'm not getting any response from my radio..no one can hear me and i cant hear anyone
This radio has many frequencies and it is easy to "get lost" Make sure you have it on the correct band and check the HI / LOW switch as this gives double the channels that are on the band switch.
1helpful
How do you set regular channels and low and high on a connex 3300
Combination of hi / low switch and the band knob, I believe C band with the switch on low will give regular channels.
1helpful
How do you properly set the settings for normal use on the Connex 3300
I am guessing that you are talking about getting it to talk on the FCC Citizens band. I am not too firmiliar with connex, but this will work with any radio with expaned channels.
Usually you use a frequency counter to see what frequency you are on when you are playing with the bands.If you do not have a frequency counter you can find the CB this way.
If its in a mobile, or you are not really far from a highway where big rigs travel, you can flip to channel 19 on the channel sellector then flip through the bands checking each time to see if you are on the CB 19. When you start to hear truckers or you get a radio check from a trucker your on CB 19. You can always ask the person, "this is 19 right"?
I recomend geting a frequency counter.
5helpful
Need to know the normal use settings for the Connex 3300 HP. Changed trucks and wife cleaned the radio; I believe the settings all got messed up. Thank you very much.
turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
2answers
Switching radio bands
what radio do you have? does it even have sideband channels? some radios don't come with them, of fm or upper or lower side bands and short wave
Radio Communications Logo
Top Connex Radio Communications Experts
Damon Nesselrodt
Damon Nesselrodt
Tom Chichester
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
