Two days is not enough for the machine to scale or get dirty from old grinds usually would be either coffee or water problem ---but depending on machine you have didnt specify- can be residue from plastic or container try running a vinegar cleanse than 3 just fresh water then try a coffee drop and see it taste is any different if no change bring back for a refund or exchange
Hi there! I'm sorry to hear that your Tchibo coffee maker is not brewing the large size coffee properly. Here are a few suggestions that might help:
Check the water level in the water tank. If the water level is too low, the machine may not be able to brew the large size coffee.
Make sure that the coffee filter is properly inserted into the filter holder. If the filter is not inserted properly, the machine may not be able to brew the large size coffee.
Clean the coffee maker. The coffee maker may be clogged, which can prevent it from brewing the large size coffee properly. You can clean the coffee maker with a mild detergent and water.
Descale the coffee maker. If the coffee maker is not descaled regularly, it can build up calcium deposits, which can prevent it from brewing the large size coffee properly. You can descale the coffee maker with a descaling solution.
If you have checked all of these things and the large size coffee is still not brewing properly, then you may need to contact Tchibo customer support for further assistance.
Here are some additional tips that might help:
Use fresh, cold water. Stale or warm water can affect the taste of the coffee.
Use a good quality coffee. Cheap coffee beans can make the coffee taste bitter.
Grind the coffee beans to a medium-coarse grind. A too fine grind can make the coffee taste bitter, while a too coarse grind can make the coffee taste weak.
Clean the coffee maker regularly. A dirty coffee maker can make the coffee taste bitter.
Here are some possible reasons why the water in your Lavazza Jolie Pod Coffee Machine leaks out of the machine and no coffee comes out of the coffee pod:
The water tank is not filled properly. Make sure that the water tank is filled to the correct level. The water level should be between the minimum and maximum marks on the water tank.
The coffee pod is not inserted properly. Make sure that the coffee pod is inserted into the machine properly. The coffee pod should be inserted all the way into the machine until it clicks into place.
The coffee pod is clogged. If the coffee pod is clogged, the water will not be able to flow through the pod and into the cup. Try using a different coffee pod or try cleaning the coffee pod.
The machine is not descaled properly. If the machine is not descaled regularly, it can build up calcium deposits, which can prevent the water from flowing through the machine properly. Try descaling the machine with a descaling solution.
The machine is defective. If you have checked all of the above and the problem persists, then the machine may be defective. In this case, you will need to contact Lavazza customer support for further assistance.
Clean the coffee machine regularly. A dirty coffee machine can make the coffee taste bitter.
If the water that comes into contact with the coffee grounds is too hot, you will extract bitter elements from the coffee. The water should not be boiling when poured on the coffee grounds. Coffee oils, fats and sediment are the natural parts of the coffee bean that causes bitterness by forming as the brew ages. The longer the coffee sits the stronger it tastes.
Article Source :
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
There may be some buildup in the machine other than in the pot itself. To test this, try running the brew cycle with no beans. Taste the hot water. If it's acrid and bitter, your problem lies in buildup (such as the basket). Otherwise, if the hot water just tastes like hot water, then the temperature of the water has probably become too high (that will make coffee tastes more bitter). If this is the problem, there's probably no fix (just make sure you fill the reservoir with cold, not hot, water).
If you are using a Claris filter, please remove this from the watertank. The descaling agent will clog the filter and make the water taste bad. After descaling, also be sure to rinse the watertank so there`s no resedue of the solvent left in the tank.
However, bitter taste on the coffe usually is related to the coffee side; Try to run a cleaning program. And check grinder settings. If the powder is to fine, it will increase the contact time, and that will make the coffee bitter. My advise is to clean the machine and experiment a little with the grinder settings.
I would check the temperature of water. Sounds like it might be too hot. The temp of the water should be between 192 and 197. Colder and its sour, and hotter and its bitter.
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
even if the machine is new use a decalfier 1 partsolution 1 part water normally when you clean start the machine turn it off for a few minute repeat until emty rinse it very good thatstuff is very corosif try after a good wash and dont forget it like a the pot the older the better hope it work cheers
