SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
SOURCE: dv328aew/xaa dryer not heating
If the fuses at the panel are ok then could be the heater, thermostats, sensor or control.
SOURCE: The dryer won't heat up.
check the motor if running? if running check the back ofyour unit when you see the exhaust pipe and clean it,and the filter inside thedryer clean it,if this one is ok.the sensor of your dryer or the heater is totally wort out,check the backof unit and look when place the heater?some model is easy to remove the heater at the back,just using screw driver,and easyto check,if the heater is continious coil it is ok,if split or broken replacethe new one,carefully to remove and carefully to return,make sure is the unit inunplug before anything to do.
