Question about NEC NP-P420X LCD Projector
HOW DO I CORRECT THE DISPLAY OF MY PROJECTOR NEC P420X SHOWING VERTICAL LINES AND BLUR DISPLAY?
Posted by MUIBI BABS on
Ravi
  • NEC Master
  • 1,682 Answers
Time to change bulb perhaps
Posted on Sep 01, 2016
Panasonic vertical color lines
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
How do I angle the projector at the side of a screen & get the screen view of it straight?
In projector menu you will find a setting called 'keystone correction'. Use horizontal and vertical keystone correction to correct the projected image.
Vertical hazy lines are all that can be seen on my LT260 (nec)
make sure the lcd cables are secure in the main board. if that doesn't fix it the polarizers may be burnt.
NEC NP1000 projector: In a corporate meeting...screen display is upside down! Help?
There should be a menu setting to flip the image vertically. Check the menu settings.
Projector
Pls Clean the optical unit and try. you have not mentioned the model, the lamp is about to finish the life.
viren
NEC Lt240 prblem
Hi 80camaro
You could check in the Service Menu if your RGB is the same percentage and at the same run rate.
The run rate is normally 45-60 and the percentage on 50.
I would however recommend that you take it to a NEC agent to get it serviced.
If this doesn't fix it , then you will be looking at a new Mainboard.
Thanks for using Fixya and good luck.
3helpful
3answers
NEC MT800 Projector with Vertical Lines in picture
The ghosting problem is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE v.com setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat.
NEC NP-P420X LCD Projector Logo
Top NEC Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
