Question about Boston Acoustics Audio Players & Recorders
Boston Acoustics Solo volume knob stopped working altogether. Turning it either way does nothing, no volume number appears. Soft reset doesn't fix it. Any thoughts?
After unplugging it and moving it to another room, the volume (centre) knob on my Boston Acoustics Solo stopped working altogether. While the radio turns on and works, it is stuck on a high volume, and turning the knob either way does nothing, no volume number appears and no change in volume happens. Soft reset doesn't fix it. Any thoughts?
Posted by Foot Solo on
Trey Coye
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I don't know if you will see this or not, your post was 2 years ago. I have the same problem. My volume is stuck at 24. I have tried soft-reset........among other things. One thread says to turn volume down to 00 then press for 10 seconds. I have no control over the volume, so, yeah, thanks for that fix. I found that I could get the volume down by unplugging it,plugging it back in and sometimes the volume would pop up and I could turn it down one notch. I did it till I got to 00.............thought AHA! My problem is solved! No such luck. When I press the volume at 00 and try to hold it for 10 seconds, after 3-5 seconds it just pops back to the station frequency. I also thought that if I could get into the guts and spray the volume control with tuner-cleaner, it might help. No go.......after taking off the cover, I found a bunch of REALLY delicate looking electrical tapes and wires..........I was scared I would destroy something in an attempt to reach the volume control. I hate to trash this radio, the sound is awesome...............great design on the speaker, NASTY design on the controls. I'd be VERY interested to know if anyone, anywhere, has found a fix for this. I think maybe my next step will be hitting it with a hammer.
Posted on Mar 12, 2018
3 Related Answers
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: Need maual for Boston Acoustics Solo clock radio
You can download the user manual by clicking this link
  • You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
For further information and specifications, click here
Hope this solves your problem. Thanks for using FixYa
Posted on Feb 21, 2010
Anonymous
SOURCE: I have a BA Recepter radio. The volume knob is loose.
quoted as $80 from BA. Buy a new radio or send to me
Posted on Jul 09, 2010
rwagoner39511
Richard Wagoner
SOURCE: Boston Acoustics Solo clock radio volume level not immediate
Old thread, but in case anyone reads this, it is NORMAL.
Posted on Apr 06, 2016
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Jun 03, 2015 | Boston Acoustics Horizon Solo Clock Radio
Why will my volume will not go past 10 on my boston duo i plus radio?
To perform a "soft reset"(all settings are erased)
Unplug radio
Hold alarm 1 button and plug in radio
Keep holding alarm 1 button until 3 numbers appear.
Release alarm 1 button and unplug radio.
Plug radio in and all will operate normally
May 21, 2014 | Boston Acoustics Horizon Solo Clock Radio
Tuner doesn't work
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off.
Mar 29, 2014 | Boston Acoustics Horizon Solo Clock Radio
My volume will not go past 10on the display and will not go any louder.
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off. This should take care of the problem.
Dec 19, 2009 | Boston Acoustics Horizon Solo Clock Radio
How can I find the product manual for the Horizon Solo Clock Radio?
Here you go buddy:
http://www.abt.com/images/products/PDF_Files/hsolomdnt_use.pdf
Nov 02, 2009 | Boston Acoustics Horizon Solo Clock Radio
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
883 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
