Question about Google Chrome
DNS Probe Finished Problem in Google Chrome Windows 8.1
Hello, I am on Windows 8.1 and continuously facing error whenever I try to visit any website on Google Chrome. I don't want to switch the browser. The error says DNS_PROBE_FINISHED_NO_INTERNET. Please guide.
Posted by Jibran on
Ibrahim K
    New Friend:
  • 14 Answers
Juned Memon
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
You can fix DNS_PROBE_FINISHED_NO_INTERNET error in Google Chrome By Applying This Method:
Open Command Prompt (Run as administrator) in your PC.
Type the following code and hit enter...
netsh winsock reset
Now simply restart your PC and error must be resolved now....
Source: DNS PROBE FINISHED NO INTERNET
Posted on Mar 03, 2017
How To Fix Google Chrome Error 105?
Error 105 indicates that Chrome can't find a DNS server.
Without a DNS server, a browser can't find a web page using a domain name (such as google.com) and therefore cannot surf the web.
If you have another browser, such as Edge, Internet Explorer, or Firefox and they cannot reach google.com either, then you are either not connected to a network with internet access or your browser has been hijacked.
If you are on a windows computer, use Windows+R or click in the Run box on your start menu and type cmd to pull up a command window. type >ping google.com and hit enter... if it pings the address successfully, then you have DNS and your browser has been clobbered.
Otherwise try connecting to another network, contact your network administrator, or examine your TCP/IP settings for your current network adapter and set your Preferred DNS server to 8.8.8.8 (google's DNS server) and the Alternate DNS to 4.4.4.4 (also google). This should give you access to the whole internet via domain names.
Sep 21, 2017 | Google Computers & Internet
What is this error dns_probe_finished_no_internet and how can i fix it
It has tried to find the internet connection and failed.
Look at you internet cable and whether the cable modem etc. is working.
Mar 18, 2015 | Computers & Internet
Error code: dns_probe_finished_no_internet
No internet, issue with connectivity. Follow steps at this link to resolve. BEST FIX DNS PROBE FINISHED NO INTERNET
Feb 23, 2015 | Video Game Consoles & Games
Eror 105 wifi
Error 105 is one of the most commonly faced errors by a lot of users everyday who are using Google chrome
Error 105 is a DNS resolution error. - Which means when you enter the URL of the website and hit enter in Google chrome, it tries to resolve the IP address of the website using a protocol called DNS (Domain Name System). If chrome is unable to reach the DNS server, the name resolution fails and you get the error 105.
Solution:
Once you have verified from your internet service provider that there is no problem on their end, follow the step by step instructions below.
We are simply going to add a manual DNS address in Windows so that chrome is able to resolve DNS queries.
1) Press [Windows Key + R] to open the "RUN Dialog"
Alternatively, you can also click on the start menu, type run in the search bar, and you will have the RUN Program.
Once you have the RUN box, type in ncpa.cpl and click OK - This would work for all Windows operating systems including Windows Xp, Vista and 7.
2) Next, Choose the correct network adapter (from the icons)
If you are connecting to the internet using an Ethernet cable, then most likely you are using a desktop computer. Right-Click "Local Area Connection" and click "Properties"
If you are connecting to the internet using a Wi-Fi Connection, then Right-Click on "Wireless Network Connection" and click properties
3) After you open the properties window, select "Internet Protocol Version 4 (TCP/IPv4)" and click "Properties"
4) Usually you would be having both the options set to "Automatic"
In the section below, select the "Use the following DNS Server Addresses" and enter the following values Preferred DNS Server - 8.8.4.4
Alternate DNS Server - 8.8.8.8
and click "OK", then click "CLOSE"
You must now test your new configuration by browsing a website - you can also try and browse the website you were trying to get to when you got the error 105.
Jul 06, 2012 | Microsoft Windows XP Media Center Edition...
Kodak printer ESP C310 printer not responding error code 105-100003
for more help visit CBR Tech Solutions
Sep 23, 2011 | Office Equipment & Supplies
How i fix Error 105 (net::ERR_NAME_NOT_RESOLVED?
Changing the DNS settings to 8.8.8.8. and 8.8.4.4. on BOTH the modem/router AND on each pc on my network in the Tcp/Ip lan or wan settings (in detail bellow) solved this ERROR 105 issue for me,
To change DNS settings (in Win 7) go to Control Panel / Network and Internet / Network and Sharing Center (may be listed as "View Network Status and Tasks" in control panel)
Next click on your connection (Local area network or Wireless area network)
click on Properties
select Internet Protocol Version 4 (TCP/IP v4)
click on Properties (yes, again, but this is a different window)
click Advanced and select the DNS tab
Select any DNS addresses here and Click remove. Make sure there are non left
Click OK. you should now be back at the "Internet Protocol Version 4 (TCP/IP v4)" window
without altering the IP settings at the top, select "Use The Following DNS Server Addresses"
in the first area write 8 . 8 . 8 . 8 .
in the second write 8 . 8 . 4 . 4 .
next either:
1 select "Validate Settings Upon Exit" and press ok
or
2 press ok and then restart the network connection for changes to take effect
(In other words find your connection in "Network and Sharing Center" and click the
"Connect or Disconnect" option above it to disconnect, then select connect to a network in the
same window, select your network and click connect")
Mar 17, 2011 | Google Chrome
Chrome Error 105
Go into the Tools area, select Options, then in the Privacy section, turn off DNS pre-fetching. Worked well for me.
Nov 12, 2008 | Google Chrome
Google Chrome Logo
184 people viewed this question
Top Google Computers & Internet Experts
Ahmed
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
