Question about Rival Kitchen Appliances - Others
I need a replacement thermostatic control switch for a Rival SK100 Kettle. The switch is made by Strix and is a model T90. Where can I find one?
Thermostatic switch made by Strix, Model T90
Posted by Michael Williams on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Replacement cover for Rival 38601 Crock Pot
No, dont throw it away!!! You can use tin foil as a lid - I do this all the time as my lid shattered too and it works perfectly. You dont have to adjust times or anything.
Posted on Jul 09, 2008
Deneenie
DLewis
  • 73 Answers
SOURCE: Need replacement lid for Rival crock pot
OKAY...I'll help you figure this out
Rival doesn't even acknowledge that model number (3154) in their replacement parts. Makes me think we either have the wrong model # or the wrong manufacturer OR more likely we are missing a few of the prefix letters to the model number.
Please double check and make sure you are looking in the right place for it...here's a pic on Rival's website on where to look on the crockpot: http://www.crock-pot.com/CustomerService.aspx?id=rpt
If you are certain it's a Rival and the number is "3154" then call their customer support # at 1-800-323-9519.
If you discover the model number does have a few prefix letters, be sure to enter that on their search page (which is the same link I posted above.)
Not sure what the replacement part will cost but for $35 you can get a used 3154 with lid on ebay: here (that kinda proves there is such a model - so you may have to call Rival at the number listed above.
If this solves it for ya, please let me know by rating this answer. If not let me know. :-)
Posted on Mar 29, 2009
Anonymous
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Posted on May 09, 2010
go_katie
go_katie
SOURCE: Replacement glass lid for Rival Crock Pot Model SCVP 550
You can get one for $10 on the Crock Pot website.
http://www.crock-pot.com/customerservice.aspx
Posted on Jan 14, 2013
jhbwrtg52000
Richard
SOURCE: finding replacement parts for rival food slicer model 1101/8
Take a look on amazon here Amazon com rival food slicer parts I hope I have helped. enjoy
Posted on Nov 22, 2014
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
Why won't our BOSCH TWK8633 stay switched on?
You don't say how old your kettle is, but if it is less than 1 month, I would go back to the retailer where you purchased. Make sure you have your guarantee or proof of purchase.... Otherwise, going by past experience, kettles that won't stay switched on usually need de-scaling. Even if you can't see any lime scale in the kettle, there are sediments in the water that will build up over time & that can cause the element to overheat. This makes the kettle switch off prematurely or not switch on at all. In the UK, regardless of where you live, you should de scale your kettle at least once a month. If this doesn't work, you should still go back to the retailer, but if it's found that the malfunction uis diue to lack of de-sclaing, this isn't usually covered by the warranty....good luck!
Aug 09, 2014 | Bosch Styline Collection Kettle Twk8633gb,...
My rival electric teapot leaks, can I send it back for replacement?
Only the dealer and the manufacture can answer this question! I doubt you will find the answer on a public news group...
Jerry G.
Jun 18, 2012 | Rival 4071-WN Electric Kettle
Not boiling anymore.
Hi.
Problem is usually either the heating element or the thermostat installed in line with the element. The heating element can be tested using a multimeter. A good element will read from 20 to 80 Ohms (depending on type and model). If the element reads open (Ohms infinity), then the part must be replaced.
The thermostat can be tested jumping its contact. With the thermostat contacts jumped the kettle will not turn off. With thermostat jumped the appliance must be turned off manually. If the kettle works with the thermostat jumped, then the problem was the thermostat.
If problem is none of the above test the kettle switch. Check also the fuse that is in the power cord (do this first). Disconnect power before performing any maintenance.
regards.
Ginko
Aug 11, 2011 | Oster Kitchen Appliances - Others
Have a problem with a Breville Classique kettle,model number jk91. It does not switch off automatically. Any suggestions please? regards Sandra Smith e-mail [email protected]
Every kettle has a thermostat/thermometer that trips the switch to off when the water reaches boiling point. The solution is not usually something you can do yourself. Your best bet is to consult the manufacturer for a repair/replacement (if under warranty). I recommend that you contact the retailer first as most retailers have an agreement with the maunufacturer to replace most small kitchen items if it's still under warranty and develops a fault.
Jul 06, 2011 | Breville Kitchen Appliances - Others
When filled with water & put on to boil it start's boiling as normal then after 10 or 20 secs.the lights inside flicker off and the kettle ceases to boil then the lights flicker back on and boiling...
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Jun 28, 2010 | Russell Hobbs 14339 Cordless Electric...
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Kettle does not heat up
yes the coil that heats up needs to be replaced....
Nov 02, 2007 | Benchmark 11065 Popcorn Maker
Rival electric skillet # S16g-CN
I have just taken apart the probe / thermostat of this model for a friend. I am an amateur, but it is such an amazingly SIMPLE piece of equipment (in the non-digital, i.e. mechanical thermostat model I'm looking at, that it is clear that the light will be "on" if the thermostat is sending electricity to the heating element, WHETHER OR NOT the element is broken or even connected to thermostat: In other words, if the light is not going on with thermostat knob in any position but OFF, the problem is with the thermostat: The pilot light goes on even if thermostat is NOT PLUGGED INTO the pan; when functioning properly, which one can observe on working pan even w/o taking it appart. But if you have digital model, this will be of less sure use to you, tho the way two yellow wires go to pilot light INDEPENDENT of power returning from pan itself, it suggests the same may be true with all their models.
Nov 29, 2006 | Rival S16 Electric Skillet
Kitchen Appliances - Others Logo
395 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
