Question about Ricoh Office Equipment & Supplies
My ricoh printer stoped printing and came up with an error code sc440-00
Posted by Vasudev More on
Linh Thy
    New Friend:
    Problem Solver:
  • 17 Answers
My ricoh printer stoped printing and came up with  - basketballgames-hvsixcj0ol34xq5mztl4udmh-4-0.jpg
http://basketballgames.io/
Basketball Games, you are the all star team. Do quick match, tournament or even play against your friends in 2 player mode. Call your friend right now, set your team and get ready for super struggles which are tough from each other.
Posted on Jun 13, 2019
Brian Friend
    Sergeant:
  • 132 Answers
The Ricoh copier error code 440 / SC440 is a main motor lock error code.
If you are receiving this error it can mean:
Your Drive mechanism is overloaded
Your Motor driver board is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Posted on Aug 28, 2016
My ricoh printer stoped printing and came up with an error code sc440-01
Possible Drum motor, or sensor - you would do best getting a professional in to repair, as self repair on these will no doubt end in issues..
Aug 28, 2014 | Ricoh Aficio 2238C Color Copier Printer
My ricoh aficio 3228c will not print in color
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
Feb 21, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Hello, We have a Ricoh Aficio AP410N Laser printer. It stoped working and gives the error code SC514. Resetting it didn't help. Could you please advise? Many thanks
There is no SC514 on an AP410N. Do you mean SC541? SC541 is a fuser code that a technician has to reset. It could be something as simple as a power spike, or it could be a dirty sensor or a blown board.
Jun 01, 2010 | Ricoh Aficio AP400N Laser Printer
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Receiving fax but not printing ricoh ac104
  1. check paper
  2. check modem, rj 45 may be in wrong slot, must be in "line" not "tel"
There are no error codes????
http://www.websitetoolbox.com/mb/copierquestions
Dec 15, 2008 | Ricoh AC104 All-In-One Laser Printer
Print problem With Ricoh 4506.
First of all E-310-285522 is not an error code.It is the Fiery printer number.
Looks like you have enabled password for this copier and ticked accidentally the "password for printing".
May 01, 2008 | Ricoh 4506 Copier
223 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
