Question about Jugs Baseball 101 Pitching Machine
My Jugs 101 machine will not maintain pitch speed over 25 mph
The machine will not pitch faster than 25 mph anymore not matter what I set it at
Posted by Brian Bonnell on
2 Related Answers
Finn
  • 60 Answers
SOURCE: my jugs pitching machine is making a rattling
It could possibly be one of the bearings starting to go, is the machine well used or new?
Posted on Nov 05, 2010
David Baughn
SOURCE: jugs 101 pitching machine , bottom motor will not
Just had this happen on my machine. Opened up the control box and found center disc capcitor was loose from cold solder joint. However we also found the hot lead for the motor at the wiring block on the circuit board had a cracked solder joint. Simply reheated with solder iron and applied little extra solder and it working again.
Posted on Oct 10, 2012
Hat is the max speed for a Jugs MVP
I think it's 70 mph not positive but pretty sure
May 06, 2014 | Jugs Mvp Pitching Machine
How to remove wheel from jugs pitching machine
Pretty sure you can take it to a tire shop and get that done
Apr 02, 2014 | Jugs Small Ball Pitching Machine
I have a jugs jr pitching machine and can't get the speed to adjust
Take off the cover and make sure the wire is connected to the knob and check the wire maybe it's exposed an not working properly
Mar 03, 2013 | Jugs Small Ball Pitching Machine
Fix jugs pitching machine wheel
What's wrong with it need more info
Mar 31, 2012 | Jugs Small Ball Pitching Machine
Jugs 101 pitching machine , bottom motor will not run ,no current at connector on circuit board
Jul 21, 2011 | Jugs Baseball 101 Pitching Machine
My jugs pitching machine is making a rattling noice in the motor area
Oct 27, 2010 | Jugs Small Ball Pitching Machine
2002 S4
I'm sure it will go faster, but you had better be hanging on. My S4 has never seen 100, I can't go that fast anymore. It is rated at 101 HP stock. Add a cam and new exhaust will up it 20HP. Hope this helps.
Apr 20, 2010 | 2002 Ducati Monster S4 Fogarty
Jugs Baseball 101 Pitching Machine Logo
165 people viewed this question
Top Jugs Sport & Outdoor - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Jugs Sport and Outdoor - Other Expert? Answer questions, earn points and help others
