Televison & Video Logo
A
Anonymous Posted on Aug 27, 2016
Hi my samsung LE32B450C4W have a Solarization problem should i buy a new T-con board ?
My samsung televition have a solarization problem neither from the menu fixed nor with factory reset should i buy a t-con board? or should i buy a new one?
Ravi
Level 3:
  • Samsung Master 1,682 Answers
  • Posted on Aug 27, 2016
Ravi
Samsung Master
Level 3:
Answers
1682
Questions
Helped
580109
Points
8910
5 Related Answers
Anonymous
  • 54 Answers
  • Posted on Feb 28, 2009
SOURCE: got a new T-con but no luck
is your back light constantly on when you are not changing channels.if so replace the main board. can you see a menu if you hit the menu button ? that is generated by your main board..... replacing the t-con will only correct vertical lines in the pic.
Anonymous
  • Posted on Jan 27, 2011
SOURCE: red hue around everything in
I have the same situation...what happened with yours
gopakumarg43
  • 76851 Answers
  • Posted on Sep 30, 2015
SOURCE: model LN40A500T1FXZA. Why is the picture solarized?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Serge Lavallee
  • 75 Answers
  • Posted on Oct 01, 2015
SOURCE: How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
gopakumarg43
  • 76851 Answers
  • Posted on Dec 11, 2015
SOURCE: How can I fix this issue. TV Symptoms: Picture Solarization - Now Black Screen
Fault at its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Testimonial: "Fixed for $105 and a technician, short chip on the main board, also chip on tcon board was bad, replaced and tv is running like new."
I have a LG 42PQ6000, 50 inch plasma TV, I think i got a solarization problem, the problem will be either the T Con board or the Main Board, which need replacing. Can anyone advise me .
It's a guessing game. The best bet is to get both and then you will have a spare, and one to diagnose and repair the faulty components on the board.
This explains the problems of the self repair of televisions
https://www.fixya.com/support/r29790007-repairing_own_television
T-con board on LG TV
Your TV is a plasma and doesn't have a T-Con board. Problem possibly connected to Main Board or Main Board Cables.
What is causing solarization?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Samsung ln40A 500TIF Problem is solarization of color; went into Service menu and selected factory reset-did not work. Do I have to replace T-con board?
Serge.
1helpful
Dp42647 screen solarization cost for repair
replace the T-Con board should fix your problem ...cost around $60 on ebay
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
