PANDIGITAL SuperNova Logo
Holly Copeland Posted on Aug 27, 2016
Resetting pattern password - PANDIGITAL SuperNova
I got locked out of my kurio
If the tablet is connected to the internet, tap on forgot password or pattern then enter gmail account to receive an email with the correct password/pattern you set.
Below are steps to recover from being locked out. The first is the most extreme. The second is less extreme. And the third is probably the preferred method.
Firs, t the extreme reset. You lose your data but it returns it to factory default condition, i. e. right out of the box.
Kurio Extreme 2 Factory Reset
Secondly, the soft reset.
Kurio How to Perform Soft Reset
Thirdly, a Kurio password reset:
Kurio Password Reset Kurio 4S Kurio 7S Kurio 10S
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
1helpful
2answers
Change pin number
hard reset by recovey options
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
3helpful
Top PANDIGITAL Tablets & eReaders Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
