There is no such chip specified as anti-theft. It is a software settings done to its main system control IC. It can't be removed by anyway, other than in its settings. A password is necessary to release it. http://electronicshelponline.blogspot.com/
If you don't know that password, the set is lost for ever. That's all.
SOURCE: 2000 Cadillac Deville DTS is in anti- theft mode
you can reset the system by turning key to on position for 5-10 mins and then try starting it but its probably a short or grounding prob try the engine to chassis ground
SOURCE: 2001 ford focus anti theft
yes its possible to disable the alarm immobiliser ,remove the ECU unit .then solder in a 12v supply from the on side of ignition,find a suitable connection in the wiring harness feed and solder to a switching transistor on the side of unit with a heat sink to the base connection of a transistor that controls the feed to another three transistors ,starter motor earth for relay,fuel pump earth relay,and ignition ,no relay and away you go location of transistors iam not saying as i dont wont the car theives reading it ,but its as easy as falling off a log when you know the colour of the wires, pin numbers and a magnifying glass soldering iron .took me hours to follow the the connections in the fuse box separating the two halves to follow circuit,tracing wires back to ECU then following printed circuit but i have done it .SO DEALERS EAT YOUR HEART OUT ANOTHER FOOD WITHOUT WORKING FOR IT JOB LOST .going to try it out on a dammed renault when i get time.Also sell the details over the internet ???? no i dont think so iam just glad i have pissed off the local dealers that wanted 200€
SOURCE: anti theft system
The chip is in the key. Either the key has lost it's program or the transceiver is not recognising the key. Try another key if you have one.
SOURCE: 2003 Ford Windstar won't start
does it have an autostart? if you have two keys (this will only work if you have two) turn the key to on in the ignition and wait till the theft light goes out do this for each key this may fix your problem.
SOURCE: Hello accent 2004 with anti theft system battery flat anti theft
Have you verified this system is running the battery down? The system you describe is called the Remote Keyless Entry System (Electronic Time/Alarm & Control System - ETACS Module). It cannot be 'disconnected' without disabling other systems (intermittent wipers, Chime bell, Door Warning, Dimming Off Room Lamp, Seat Belt indicator, remote power door lock/unlock system, etc.)
