Question about Garland S18F - 30-lb Range Match Fryer w/ Thermostatic Controls
Hello ,Do you have a wiring diagram for a GARLAND S18S ELECTRIC FRYER,its 3 phase and want to wire it single phase ,there site say you can ,but they dont have the diagram..Help...Thanks Steve
Going from 3 phase to single phase need diagram
Posted by STEVE on
Wells deep fryer 208 volt 3 element. 1 element works other two don't working left to right. Continuity good resistance good. Relay problem?
Sounds like this maybe a three phase unit and you are powering it off on single phase power. Most can be converted to single phase but will draw three times the current and requires some wiring changes. It needs to be on a three section breaker for 3 phase.
Jul 21, 2014 | Kitchen Appliances - Others
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
I am trying to convert a wells f-67 to three phase and need a wiring diagram please help
Hi there.
You can download Wells F67 electric fryer at http://www.wells-bloomfield.com, it contains conversion of wiring from single phase to three phase, just click the owner's manual on Service and Support page.
Regards.
Oct 17, 2011 | Wells F-67 21167 Deep Fryer
I have an old GE deep fat fryer,m/n CK40B, which has no wiring diagram, I am trying to use it for my shop, but can't find any diagrams anywhere on this fryer. It was wired for 3 phase, I am trying to...
If you feed single phase into the line terminals, you will get only 1/3 the heat wattage. To get all heating elements working on single ph, you'll have to separate the common ends of the elements, then connect all 3 in parallel. Keep in mind, doing so will raise your line amperage x3 also. That may put you over the contactor's max rating. Another thing, the contactor will activate on only one sequence of single phase. You may need to move the line to another 2 of the 3 connections.
Feb 02, 2018 | GE Kitchen Appliances - Others
How do I switch the wiring for a Garland Model S 686 -2 Stove from Single Phase to 3 Phase?
If the oven is a three phase oven currently wired on single phase there will be three active terminals at the terminal block. There will be links or bridges which connect the single phase to each of these active terminals. Remove these links and connect each phase to each terminal.
Feb 24, 2011 | Garland S686 Electric Kitchen Range
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Nov 03, 2009 | Kitchen Appliances - Others
Converting from three phase to single phase
I have 3phase blue seal electric fryer how can it be converted to single phase please? i have been toild it can and it will take 45amp fuse. please advice.
May 07, 2009 | Kitchen Appliances - Others
HELP PLEase
Hello. Here is the link to your units manual, page 3, 7, and 13 tell most of the specs, page 13 has a part number, and specifications for the proper cord.
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20OpM/301(b)%20307588%20OpM%20CT%20Std%20Fryer.pdf
Lowes probably does not have that high an amperage plug first of all, find an electrical supply house, or have an electrician get it and install it for you. You may actually have a 3 phase unit, but it does not specify that unit as being set for 3 phase, older units from a certain restaurant were though. If you want to find the terminal block, remove the pot, and then remove the inside rear cover, once removed you should find the terminal block inside, your wiring for the cord should go here ( a wiring diagram ).
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20Wir%20Diag/307309.pdf
Hope this helped, and thank you.
If you need more help, ask me.
Apr 12, 2009 | Wells F-55(21154) Deep Fryer
Just bought new wells deep fyer # F-67
i had an electrician look at it. he told me the unit is wire for 3 phase, my plug is a single phase. he rewire the unit and it working good. problem solve.
Jan 26, 2009 | Wells F-67 21167 Deep Fryer
Garland S18F - 30-lb Range Match Fryer w/ Thermostatic Controls Logo
318 people viewed this question
Top Garland Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Garland Kitchen Appliances - Other Expert? Answer questions, earn points and help others
