Question about Amana Dehumidifiers
How do I take the covers off of my amana D970E-E. All screws are out but covers will not come off
Posted by Chris Wooldridge on
I am looking for an Amana Dehumidifier manual for D965E-R
Google (amana)(D965E-R)(manual) without parens.
Sep 13, 2018 | Amana Dehumidifiers
Is there a recall on this product? My compressor and fan run but no water is collected. I know other Amana dehumidifiers were recalled for fire risk due to compressor overheating so I took cover off and...
Your description indicates a loss of refrigerant in the dehumidifier. The metal heat exchanger above the water collector should become cold when the compressor is running - if it does not, your dehumidifier likely has lost it's refrigerant charge. You will have to take it to a certified (refrigerant handling) technician to repair. It may make more sense to replace with a new dehumidifier.
Check the CPSC website for dehumidifier recalls. they will have details of the brands/models/serial numbers of recalled units.
Oct 23, 2013 | Amana D545M Dehumidifier
Has there been a recall on this product? My compressor seems to run but no water is collected. I took the back cover off and the compressor is extremely hot and I know that other Amana dehumidifiers were...
Need to replace a gas manifold for an Amana GCI 90A30 gas furnace. The part number, D6995003 is an obsolete Maytag part number since Goodman bought out Amana. I either need to find a source for the part or...
You could Purchase the Part from :-
http://www.apwagner.ca/index.php?main_page=product_info&products_id=486717&language=en
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 27, 2010 | Amana Dehumidifiers
How does the unit collect water?
Your fan motor is going out. You can remove the screws from the back cover and gently pry it off. After that, look into the unit and you will see the screws holding the front cover. Take the bucket out and remove the screws at the top. All the screws around the entire metal shroud need to come out. Then with the covers off you can see the fan mount screws. You have to move the evaporator very gently out of the way to get to these screws. Remove the fan motor replace it and re assemble the unit.
Oct 03, 2009 | LG LHD65EBL Dehumidifier
I have a dehumidifier in my basement and attached a garden hose to the outlet and have it draining into the sump pump drain--however it's draining into the bucket and not through the hose. And I cannot...
WHEN I BROUGHT MINE I HAVE A HOSE RUNNING TO A FLOOR DRAIN BUT REMOVE THE HOSE SEE IF THERE IS A PLASTIC COVER INSIDE WHERE THE HOSE HOOKS ON FROM THE FACTORY THE CONDENSATE PAN IS MENT TO HOLD WATER AND THIS PLASTIC PIECE HAS TO BE REMOVED FOR HOSE USE
Aug 23, 2009 | Amana Dehumidifiers
Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Nov 04, 2008 | Amana D530M Dehumidifier
Dehumidifiers Logo
236 people viewed this question
Top Amana Dehumidifiers Experts
NOEL
NOEL
Tom Chichester
Terry
Terry
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
