Question about Lexmark X Office Equipment & Supplies
My Lexmark printer will not retrieve application list!
Printer refuses to download application list!
Posted by Faye Zahorchak on
5 Related Answers
Anonymous
SOURCE: scanning with my printer
Funny you just posted this yesterday and I had the same problem at the same time. (driver timb bomb?) Any way, the solution that worked for me was to: 1. Unplug the printer. 2. Uninstall the drivers. 3. Reboot the machine. 4. Go to the lexmark site and download the drivers. 5. Install the new drivers. Everything is working great now. It is nice to have simple solutions once in a while. :)
Posted on Aug 21, 2007
Anonymous
  • 29 Answers
SOURCE: Lexmark X5495 can't scan, Downloading application list
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
864
Posted on Mar 02, 2009
Anonymous
SOURCE: Cannot scan anything on my lexmark 4550
There is a patch that you can download and run to resolve this issue.
Step 1:
Download the following patch: http://swdownloads.lexmark.com/Patches/3500-4500/3500-4500.exe
  1. To start the process, double-click on the downloaded file and follow the on-screen instructions to continue.
  2. Reboot the PC.
  3. Unplug the power adapter from the back of the printer.
  4. Plug it back in after 30 seconds.
  5. Try to scan again.
    If the problem still exists, follow Step 2 below.
Step 2:
Download the following patch: http://swdownloads.lexmark.com/Patches/3500-4500/3500-4500wifiethernetpatch.exe
  1. Double-click on the downloaded file and follow the on-screen instructions to continue.
  2. Reboot the PC.
If the problem is still the same
1.Get the printer ip address of the printer (ex: 192.168.1.10)
-press settings on the printer panel.. go to network setup.. View TCP / IP, open a browser (IE or mozilla) and type in the printer ip address
-you will see the printer page and then go to configuration.. choose scan to network host
-delete all the computer name listed
2. Go to start, all program.. choose Lexmark 3500-4500 series and choose Lexmark Solution Center
-go to Advanced, click on networking and then click on Change PC name or PIN
--rename the PC name and then click on Ok
3. Turn off the printer, unplug it for 10 secs
4. Try to scan, it should work
if it's still the same you need to uninstall the printer driver and download the updated driver in Lexmark.com
-reinstall it using the downloaded driver
GOODLUCK!!!
Posted on Sep 25, 2009
lucymcgough
SOURCE: Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Microsoft Paint ----> 'File' -----> 'From scanner or camera' (while the Lexmark is in scan mode). Just tried it and it really works.
Posted on Jul 07, 2010
lucymcgough
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Scanner for X6575 says it cannot retrieve application list
Hi, i had the same problem with my x5075 . I had to uninstall and then re-install that brought my application list back.
Sep 03, 2015 | Lexmark X6575 Wireless Professional...
Application Download
If you turn off the printer and then back on. This may clean the problem.
Dec 30, 2013 | Lexmark X5650 All-in-One InkJet Printer
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
"Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Cannot retrieve applications listo lexmark 3500
my printer will not scan when i try it tells me downloading applications list then it will not download it tells me cannot retreive applications lists and i have reinstalled the disc and still nothing
Jan 27, 2010 | Lexmark X5470 All-In-One InkJet Printer
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Mar 07, 2009 | Lexmark X3350 All-In-One InkJet Printer
Oct 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Scanner
Reinstall the software/drivers and try again.
May 23, 2008 | Lexmark X3550 All-In-One Printer
720 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
