RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
A
Alma Barron Posted on Aug 25, 2016
After being plug in for 12 hrs the red Light only is on...no green light flashing...is my unit DEAD ?
Moto master 1000booster pack....500 amps...
2helpful
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
1helpful
WHy is air hog battery charger flashing red
I had a Storm Launcher battery that was unused for sometime and when I plugged it in to the charger, the light flashed red. I checked the voltage of the pack and it was down around 2.5V....from 7.4V. I figured the "smart charger" thought it had a dead or shorted cell and wouldn't kick in the charging circuit. I McGyver'd the two probes and alligator clips to connect the pack to a 9V. NiCad "dumb" charger. The light came on showing a charge and I left it for 5 mins. Unhooked it and checked the voltage. It was now 5 volts...supposed to be 7.4...but much better than 2.5. Plugged the pack into the AirHogs charger and the green light started flashing, indicating a charge. Later I got the double-flashing and 10 minutes after that FULL charge! Just needed a boost to start the smart charger.
Doesn't spin & Power light flashes red to green
This situation indicates a problem with the built-in self tests. Most likely a power supply failure. I don't believe it is economically feasible to replace the power supply. If it is still under warranty, I'd go through the procedure to get it repaired/replaced. Otherwise, you'll need to replace the unit.
3helpful
2answers
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Doesnt seem to charge
Sounds like the battery is bad in the unit. If it's a first generation unit, Apple isn't supporting them anymore.
You could try hooking up one of these units:
http://www.google.com/products/catalog?q=battery+for+shuffle&cid=14549207473407394801#ps-sellers
Dash warning lights
These things seem to differ depending on where they were delivered and the fact that the bulb holders can be switched around easily doesn't help. Mine was delivered as follows: Red = Low oil pressure Yellow = Headlight on Green = Neutral... or maybe not Blue = high beam I've rewired my yellow to flash with the turn indicators 'seems more useful to me.,,
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Top RoadPro Air Tools & Compressors Experts
Kardoc
Tami Scott
Tami Scott
Level 1 Expert
Larry Ng
Larry Ng
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
