Samsung GALAXY S4 Logo
C
Crystal Barker Posted on Aug 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clear my reject list? I tried to add a number to the reject list and was told it is full
Christina
Level 3:
Master:
  • Samsung Master 233 Answers
  • Posted on Dec 20, 2016
Christina
Samsung Master
Level 3:
Master:
Answers
233
Questions
0
Helped
167318
Points
1422
I always use LEO Privacy to block unwanted calls, if I want to clear my reject list, I just need to go into LEO Privacy's Harassment Intercept feature, this is a very useful applock. LEO Privacy Applock Hide Safe Android Apps on Google Play
THAKAR CHETAN
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Aug 29, 2016
THAKAR CHETAN
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
5588
Points
59
Check settings there is auto reject is on, so do it off and select option clear all than add new number
5 Related Answers
Anonymous
  • Posted on Jul 12, 2009
SOURCE: can't remove number from reject list
Menu>Adrdress book>#5(reject list)>Hope it helps. :D
Anonymous
  • Posted on Jul 18, 2009
SOURCE: in samsung mobile how to remove the number from reject list?
fallow these staps
satting- application satting - call - all call - auto reject - reject list-
click option and remove number from reject list
Anonymous
  • Posted on Aug 05, 2009
SOURCE: cannot bring up call reject list on samsung sgh-a707
Menu
Settings
Call Settings
All Calls
Auto Reject
Reject List
Press center key
Scroll to number
Options
Delete
Anonymous
  • 93 Answers
  • Posted on Dec 17, 2009
SOURCE: removing numbers from reject list in samsung f480
Goto
Settings-->Call settings-->All calls-->Auto reject
Click on 'Reject list'
Here just for making them to be receivable calls, uncheck them
If you want to completely remove, you need to click on each entry and then press Options-->Delete. But the problem with deletion is you need to do that for each entry separately.
Anonymous
  • 184 Answers
  • Posted on Mar 05, 2010
SOURCE: removing a number from reject list in my Samsung GT-S5233A.
Hi ,
just go into menu , settings , application settings(5), call (1), all calls( 1) , auto Reject (2), scroll down to reject list and you will find all numbers added to it, simply delete them and they will be back as normal in your phonebook,
hope that'll help you
2answers
HOW DO I ACCESS MY REJECT LIST ON MY SAMSUNG GT-E1270
try this: (A complete guide on how to block/unblock a number)
1. From the home screen, press Menu.
2. Scroll to Settings, then press Select.
3. Scroll to Applications, then press Select.
4. Scroll to Call, then press Select.
5. Scroll to All calls, then press Select.
6. Scroll to Auto reject, then press Select.
7. Press Options.
8. Scroll to Create, then press Select.
9. Press OK.
10. Scroll to the required option (e.g. Contact list), then press Select.
11. Scroll to the required number, then press OK.
12. Press Options.
13. Scroll to Save, then press Select.
14. The number has now been blocked. Click Next to continue.
15. To unblock a number scroll to the required number, then press OK.
16. Press Options.
17. Scroll to Save, then press Select.
18. The number has now been unblocked.
3answers
Block unwanted calls
yes, in phone number recall area. number history. find number you want to block hit settings then add to reject list.
1helpful
3answers
How a number remove from reject list in samsung c3322
Goto
Settings-->Call -->All calls-->Auto reject
Here just for making them to be receivable calls, uncheck them one by one,, By clicking on each entry and then press Options-->Delete. Hope this will be usefull
4helpful
How do i block messages and calls from a certain number??
Thanks for posting on fixya and we are pleased to help you at the earliest.
You can either call up the service provider of your SIM card and block the number or you can reject call with the following simple steps. To reject calls from certain numbers automatically, use the auto rejection. To activate the auto rejection and set up the reject list, 1. In Menu mode, select Settings ? Application settings ? Call ? All calls ? Auto reject. 2. Scroll left or right to On. 3. Select Reject list. 4. Press ? Add ? New. 5. Enter a number to reject and press . 6. Repeat steps 4-5 to add more numbers. 7. Select the check boxes next to the numbers. 8. Press ? Save. 9. Press .
Hope it helps you. Great time. I appreciate your valuable feedback.
9helpful
Remove number from reject list on a Samsung S7350 I have tried options in call log but it dosent give me the option to remove calls only to add or not new numbers
this should work,go into settings,then call settings,then all calls then auto reject and then click on your reject list,i hope this helps.
1helpful
2answers
Block a number on my Samsung d500
hi,
try these steps, press your call key, it will give you the call log menu, press options, under options, you will see add to reject list, highlight the add to reject list and select the number you want to block.
or you may try to do these,
press menu, under menu, select settings, under settings, select application setting, under application settings, select call, under call, select all call, under all call settings, select auto reject, under auto reject menu, highlight the reject list, then add the number, highlight search and it will give you the following options, call log and phone book, select from the two and search and add the number you want to block, select activation on and select save.
regards..
14helpful
2answers
I am unable to remove contact numbers from call reject list, of a samsung c3053 mobile. In my call log menu there appears ''add to call reject list''. But in nowhere I have found the call reject list. In...
Go to Menu,
Salect Application Setting,
Salect Call,
Salect All Call,
Salect Auto Reject,
Salect Auto Reject On Or Off,
Remove Perticulers Number From Remove List,
Salect Reject List
U see Reject List
Jan 02, 2010 • Cell Phones
4helpful
2answers
I have a samsung tocco f480 and i add numbers to the reject list but the numbers still call without being rejected what have i not done?
Just goto
settings-->call settings-->all calls-->Auto reject
Make sure that it is 'on' for activation. Also click on 'reject list' and make sure the number you want to be in reject list is being checked with a check mark.
212helpful
5answers
How do i remove a number from the reject list of the samsung C3050?
Settings> Application Settings> Call> All Calls> Auto Reject> Reject List> Delete
331helpful
8answers
I need to remove a # from the rejection list
go to - menu-> settings-> application settings->  call->  all calls->  auto reject-> (scroll one down) reject list->
[on the reject list uncheck number you wish to remove from the reject list. ]
-this is the most accurate answer, trust me.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
