Question about LG Televison & Video
LG 50PZ750-UG Intermittent picture and sound.
There is a short burst of sound like a buzz and a horizontal bar of fuzzy color near the top of the screen green or yellow?. (This has since changed to a brief flash followed by the same black screen) This is followed by a black screen and a lack of sound. These episodes last less than one minute in which the tv does not appear to be power cycling and does not display menu or anything when commanded by remote, though the blue led flashes when pushing buttons. It takes several times of pushing the power button on the tv for it to power down. These episodes are most frequent nearest the time of powering on usually just happens once, and can be problem free for hours. After this the picture and info bar appear at the top of the screen, everything is again normal. I am afraid soon it just won't work at all and so it must be fixed now. I need to know what boards I should replace. Thank you for your time. -update one day later- Now there is no picture or sound at startup, One time I turned it on and It briefly worked then the horizontal lines again, then blackness. What so I do? Replace a bunch of suspect boards, Y sustain, z sustain, Buffers, power supply, logic control?
Posted by Anthony Cooper on
Marvin
    Top Expert:
  • LG Master
  • 85,239 Answers
It is likely the best thing to do here money wise is replace the TV.
Posted on Aug 25, 2016
  • Anthony Cooper
    Anthony Cooper Aug 25, 2016
    Do you have any suggestions about a specific board that might need replacing?
  • Marvin
    Marvin Aug 25, 2016
    I trust Vizio. Mine (42" LED) is still going strong and it is 10 years old and watched everyday all day. Vizio is highly rated and low in cost.
Plasma tv model number 50pz750 no sound poor picture. so how do i fix that
Main power regulator board fault. Check and replace it. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 22, 2017 | LG 50PZ750 50 3D Plasma TV
Why is there no sound, no picture?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 21, 2015 | LG 50PZ750 50 3D Plasma TV
Intermittent black or snowy horizontal bar across the top
You're somewhat sound in electronics I assumes. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | JVC PD-42WV74 42 in. Plasma EDTV
JVC vm-42wv74 television with horizontal fuzzy or black bar
Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | JVC 42 in. LCD TV
LG LCD TV - Buzzing Sound and Faint Horizontal Lines
From your description, the sound you are hearing is the inverter(s) that drive the back light for the LCD screen/module.
The inverters mounted on the back side (one lower right and one left side) of the LCD screen/module. They are under the sheet metal cover/shields.
The inverters are going out and or the LCD screen/module is going bad too.
That LG TV has only a 1 year on parts and labor from the date of purchase, but you could call LG and ask for their help for such a new TV. They might do it under a warranty, for little or no cost to you.
I hope this information has helped you.
Good Luck.
May 23, 2010 | LG 47LG70 42 in. LCD TV
My magnavox tv is making a buzzing sound, no picture, and wont change channels (just a dark screen)
Something has shorted in the set causing the power supply to make that buzzing sound. Most likely the short is in the horizontal circuit. The horizontal makes the high voltage work which in turn lights the picture tube.
Oct 15, 2009 | Televison & Video
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
TXJ2066 Samsung
  • your problem is due to crt getting weak
  • because of that you are getting fuzzy picture.
  • good luck.
Oct 23, 2007 | LG 30FS1D TV
Televison & Video Logo
140 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
