First if the error code is "EE" then unplugging unit from power<waiting a few minutes and then plugging it back in might reset control board.
Second, are you sure it is "EE" and not "tE" or "fE"?
good luck
LG Washing Machine Displaying Fault Code IE or 1E
WM2016CW
WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
it says the following:
E13
Condition
Water leak in the tub or air leak in pressure-switch air hose
Check/Repair
The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts
Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
E13
Condition
Check/Repair
Shop Parts
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
IE = Inlet Error. if the water level has not been reached in a certain amount of time, you will get an IE code. Most likely cause is clogged inlet water screen, inside the threaded end where the hose attaches to the machine. Other possiblities are valve shut off, kinked hose, open water inlet valve solenoid coil.
