Take your Nextbook to a local repair shop. Those charging ports are usually replaceable, but it requires knowledge of soldering and you need some expensive tools in order to do it yourself!
hi jennifer just follow my simple steps..
first you check your nextbook charger is it flowing the power of charging is as require to your book if its more than actual then change charger and decrease total charging and recharge freshly.
if still having the same problem then make fully format your book reset or vanish all data from your book.
after doing these such things then flash your nextbook software from the authorized store.
your problem get solved..
I don't know if this is available on that model. Give it a try. Press and hold the power button until you get the menu with the option to power it off. Press and hold your finger on the option to power it off for a few seconds. Hopefully you get an option to reboot the tablet into safe mode. This mode will disable all third party apps on the tablet. See if it freezes up. If it doesn't one of the apps is causing it to hang. This will at least tell you if the tablet itself is bad or if it is a problem with an app.
