I can change line spacing but these lights are always on.
Try turning it on remove the batteries check the contacts for clean replace the batteries in the correct direction.
Testimonial: "I replaced the battery holder with a new one I had. It was not the batteries or holder. The ground cable on the right side of keyboard where it connects to the typewriter frame was loose. I tightened it and the indicator lights work as they should."
SOURCE: IBM Wheelwriter 10 (Ser II) Frozen w/ Blinking Indicator Lights
Try reinstalling the printwheel.
DickyO
SOURCE: IBM Personal Wheelwriter 2 by Lexmark not working
It sounds like the keyboard is going bad see my tip under WW1000.
DickyO
SOURCE: IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
SOURCE: When I turn on my wheelwriter 1000 it beeps 5
First be sure the printwheel is installed properly, and look for debris in that area. Put some light oil on the silver shaft that the carrier slides on (WD40 is good).
DickyO
SOURCE: IBM Wheelwriter 1500 Beeps 6 times and then 1, 2
Few things to check. Turn the T/W off and be sure the carrier moves back and forth easily, if not look bfor debris in side machine, lube the silver carrier shaft with some WD40. If these fail you are looking at a board or metal debris on or under the board.
DickyO
