Question about KitchenAid KFP750 Food Processor
KFP750 Food processor: motor seems to be frozen. Can it be repaired?
I hear a hum when I try to turn it on, but the shaft doesn't turn.
Posted by LuanneKo on
Bill Boyd
    Top Expert:
  • KitchenAid Master
  • 53,816 Answers
Repairing these items are not cost effective
you can take it to an appliance repair shop but parts if available will be close to the cost of a new unit
Posted on Aug 24, 2016
Can't remove the container from the motor housing
It will be the blade holding the bowl on. The blade has become locked onto the motor shaft, in the end you are going to need to replace both. Take it to a K/A service agent.
May 22, 2012 | KitchenAid KFP750 Food Processor
The motor popped when I first used it. I had a US version (110 volts) and plugged it into Australian plug with adapter at 240 volts. Any ideas?
All the adapter did was enable you to put 240VAC straight into your 110/120VAC coffee maker. You needed a step down transformer to drop the voltage from 240 to 120 VAC. This is not what you wanted to hear but you have damaged your coffee maker substantially by using the wrong voltage. Also the US version is designed for 60 HZ power vs AU 50 Hz power unless stated otherwise on the input power data plate.
Damage that has probably taken place:
1. Motor PN 8211837
2. Relay and Switch assembly PN: 8212011. .
3. Capacitor PN 8211608
Cost to repair... will be close to total replacement value due to shipping costs & customs of replacement parts
Thanks for choosing FixYa,
Kelly
May 13, 2011 | KitchenAid KFP750 Food Processor
How to remove motor shaft sleeve from KitchenAid Food Processor?
I just did this. I used a screwdriver and some needle-nose pliers to wedge and separate the shaft from the base. Once you've separated it by about 1/2 inch, it will come off easily. I simply used a mallet to install the new one.
Mar 06, 2010 | KitchenAid KFP750 Food Processor
Attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
Jan 11, 2010 | KitchenAid KFP750 Food Processor
The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Mar 12, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
The spindle (middle thingie) is broken
I don't know about the little lip you're referring to, but the central spindle that comes up from the base of our KitchenAid 12 cups food processor KFP750WH0 splintered and broke while we were using it. We ordered a replacement motor sleeve shaft part number KA8211849 from the Gourmet Depot for $4.95 plus $3.50 s/h. Removing the broken plastic sleeve shaft was the difficulty; it isn't glued or screwed on but somehow it didn't want to be pulled, pried, or cut off. With the help of our neighbor fix-it man and all four of us working at it with screwdrivers, we got the old broken part up and off. Pushing the new one onto the metal motor shaft was easy, and it was fixed!
Jan 16, 2008 | KitchenAid KFP750 Food Processor
KitchenAid KFP750 Food Processor Logo
310 people viewed this question
Top KitchenAid Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Zhareese
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
