Some model Sharp sets, they have used the Philips main board. Yours should be one like that. These blinking codes denotes it. That means; your TV is a not duplicate one. Sharp did it for some sets of their own. So, when you try to count the blinking codes of such set, you should follow the way of how to count the blinking codes to Philips TVs.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
SOURCE: no picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
SOURCE: sharpaquos 32' TV model LC-32D44U WILL NOT STAY
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, Sharp in your case, Now, this last point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
static.compusa.com/.../Sharp-LC-32D44U-LCD-HDTV-Manual.pdf - United States
Above is your user manual, and below is your service and repair manual should you wish to DIY, not really recommended, however I have included it for your convenience.
http://elektrotanya.com/sharp_lc32d44u.pdf/download.html
SOURCE: LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
SOURCE: I have a Sharp LC-
you need to check first the power supply board this needs to open the back cover of the TV.The power supply board is where the power cord is connected.there are 3 voltages present on it in order to operate the television.first is 5 v for main cpu,12v for sound and 24 volts for backlight.if one of this voltages is missing TV will not operate normal might as well dead set. use a multimeter to measure the voltages.and post back for your finding and will proceed to further trouble shooting..thank you
Replaced the main board now at power up I get 1 long and 1 short. Any resets or something after board replacement?
