Question about Samsung SCX-4623FN Mono Multifunction Multifunction Laser
HOW i can reset scx 4623fn printer chips reset?
Posted by Roshan Rijal on
4 Related Answers
christine346
SOURCE: how to reset samsung scx 4623F or scx
My Samsung SCX-4623F fax machine keeps switching itself off. How do I stop it doing this?
Posted on Jul 08, 2010
Anonymous
  • 24 Answers
SOURCE: how can I reset chip
I am presuming you want to reset all the systems settings to the factory defaults. Try this:
Clearing memory
You can selectively clear information stored in your machine's memory.
1 Press Menu until Maintenance appears on the top line of the display.
2 Press the scroll button ( or ) until Clear Settings appears and press OK.
3 Press the scroll button ( or ) to select the item you want to clear.
• Paper Setting: Resets all of the Paper Setting options to the factory default.
• Copy Setup: Resets all of the Copy Setup options to the factory default.
• All Settings: Resets all of your settings to the factory default.
• Machine Setup: Resets all of the system settings, such as the display language and save
mode, to the factory default.
4 Press OK to confirm clearing. The selected setting is cleared.
5 Repeat steps 3 through 4 to clear another setting.
6 Press Stop/Clear to return to Standby mode.
Posted on Nov 30, 2010
Nikolay Boychev
  • 525 Answers
SOURCE: i have samsung scx 4300
This is a link to view how to reset: http://www.youtube.com/watch?v=Qzc9JImUcak
This is a link to download firmwares (version 1.13, 1.16, and 1.18_fix) and download software to update firmware files to printer: http://dox.abv.bg/files/listtree
MOST IMPORTANT:
1. Push 8 times button MENU then OK to print a report and view your version of firmware
2. REPLACE FIRMWARE VERSION 1.13 ONLY WITH 1.13_fix
3. REPLACE FIRMWARE VERSION 1.16 ONLY WITH 1.16_fix
4. REPLACE FIRMWARE VERSION 1.18 ONLY WITH 1.18_fix
5. REPLACE FIRMWARE VERSION 1.21 ONLY WITH 1.18_fix
6. DO NOT REPLACE FIRMWARE VERSION 1.23, I DON'T HAVE FIRMWARE VERSION 1.23
IF YOU REPLACE FIRMWARE VERSION WITH WRONG VERSION A "SCANNER ERROR" OCCURS AFTER SEVERAL MONTHS WHICH MEANS YOUR SCANNER MATRIX IS BURNED OUT AND MUST BE REPLACED
GOOD LUCK!
Posted on Jan 24, 2011
chinhkt_fint
SOURCE: SCX-4623FN Toner Reset
Samsung SCX-4623F V2.01.00.99f link to download
http://www.ziddu.com/download/16292325/reset_Samsung_SCX_4623F_v99.zip.html
Posted on Sep 05, 2011
Error #04-002 in samsung scx 4623fn
mi impresora se bloquea a penas doy la opcion de imprimir funciona y cuando supuestamente va a coger la hoja queda bloqueda ssale q es error #04-002 no se q hacerl ya le revise y no tiene atasco de hojas ni nada q debo hacer si solo dece q la apague y la vuelva a prender pero no funciona
Jan 29, 2013 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-3200 FUSER UNIT FAILURE #U1-2113
fuser unit failure #u1-2113, how to solve this problem?
Jan 15, 2012 | Samsung Office Equipment & Supplies
Counter reset of samsung scx 3201
we have solution for all model of samsung printers
ML 1640/2240/2245/1911/2525/2526/1660/1665/2580/2850
SCX 4300/3200/4824/4828/4600/4623F/4623FN ETC
CLP 315/320/310/325 ETC
[email protected]
Jan 19, 2011 | Samsung Office Equipment & Supplies
Counter reset software for Samsung SCX-3201 Printer
CALL ME ALL THE SOFTWARE IS FREE FOR CHIP RESET 9352725376
Jan 06, 2011 | Samsung Office Equipment & Supplies
Samsung ml1640 resetting software
Hack samsung ML1640 Laserjet
I found the solution for resetting the printer without any instrument.
If you are intrested contact [email protected]
Its very easy and you can refill until your drum disposed.
Arun S
Kerala
India
Apr 20, 2009 | Office Equipment & Supplies
Samsung SCX-4623FN Mono Multifunction Multifunction Laser Logo
199 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
