Question about Honda Landa PG 3500 PSI Pressure Washer
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Posted by Jermaine Hinds on
richie46
    Top Expert:
  • Honda Master
  • 12,962 Answers
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Posted on Aug 22, 2016
Honda 13 hp won't start...back fire's
Assuming that the engine has not been taken apart and timing is set correctly. Have seen this often. Usually valve adjustment. Adjust valves as per manual so that compression release is working. If compression release is not working after adjustment check for faulty cam.
Oct 22, 2011 | Honda Landa PG 3500 PSI Pressure Washer
My hot water is not working i have power to relay that is new but it will not send power to my on off switch
I am a little confused by your question because a PG is a cold water pressure washer. In most mobile hot water machines there will not be a relay. My best guess is that you are talking about a GFCI that is not sending voltage to the On/Off/Burner cam switch. To check this you will need to verify that voltage is actually passing through the GFI. If you can clarify with a model and serial for your machine, I will be able to give you better trouble shooting instructions.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Dec 31, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Honda 13 hp will not start, will run on starting spary, new spark plug, has knocing noise before stopping
If this machine has been sitting for an extended period of time it is likely that you have a couple of things going on. First you should drain the fuel from the gas tank. Next remove the bowl from the carb and using a flat head screwdriver remove the mainjet from the carb. Check that it is clear then re-assemble. Next pull your spark plug. Put a rag over the hole in the head where the plug was and pull the engine over a few times. Re-install the plug. Now remove the grey oil dipstick from the engine and check for the oil level being over full. If it is drain the excess.
Doing all of this should solve your issue. In most cases the problem you describe is caused by varnished / rotten fuel, a faulty carb float allowing fuel to drain into the crankcase creating excess pressure or water buildup in the cylinder creating excess pressure.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Nov 28, 2010 | Honda Landa PG 3500 PSI Pressure Washer
There are 2 different places to add oil to my 3500 Honda engine pressure washer (cold). Do I use SAE 30 for the motor oil and gear oil for the other oil?
you can use sae 30 in the motor and hydraulic oil or gear oil in the pump.
just note that there may be two oil filler holes on the motor.
Nov 25, 2010 | Honda Landa PG 3500 PSI Pressure Washer
13 hp honda pressure washer 3000 psi 4gal/min Hard to start and dies out after 20 seconds after the engine gets hot and running after multiple starts the engine will stay running but then dies every 30...
There are a couple of things that can cause this problem. The first thing to check is if you are loosing spark. Dying after it gets hot sounds like to stater is failing in the engine. If you loose spark this is more than likely the issue. If you are not loosing spark you need to check the fuel system. Dying after 20 seconds it could also be a plugged main jet in the carb. Another common issue on Honda engines is a faulty vent on the gas caps for engines sold from around 2008 - late 2010. If your gas cap is only about 3/8" thick this is very likely to be your issue. Try running the engine without the gas cap on to see if it still dies. If not that is your problem.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Nov 03, 2010 | Honda Landa PG 3500 PSI Pressure Washer
When chemical injector is attached, it works fine. When I put one of the power tips on, I do not get any pressure.
When using the chemical injector your machine is only having to operate under low pressure. This means that your pump only has to transfer water and does not have to compress it. When you insert a pressure nozzle you cause the pump to have resistance and therefore it has to compress the water to make pressure. If you pump seals or valves are worn the pump cannot build this pressure. You need to either rebuild your pump yourself or have it looked at by a service center. If you have any other questions or need parts or service please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Sep 23, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Cuts off when you try to spray
The problem you are describing lies in the engine. In most cases this can be cleared up by doing a tune up. In the meantime you can try choking the engine slightly and see if that keeps it running under pressure. This will usually solve the problem with the smaller GC and GX series Honda engines until you can do the general maintenance.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Aug 01, 2010 | Honda Landa PG 3500 PSI Pressure Washer
13hp honda motor what is the right psi for it
It will depend on the pump that you have but the most common versions will be the 13HP PC4-35324 which is a direct drive unit or a PG4-35324 which is a belt drive unit. In both cases the machine would be 4GPM at 3500PSI.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Jun 03, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I have a landa hmp-4-3500 heated pressure washer and i am problems with the water heater. where can i find a trouble shooting guide for this machine
Landa does not have a model HMP so I am not sure which machine you have. If you can provide a full model and serial off of the model tag on the machine I can provide you with a digital copy of the manual you are looking for.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
May 19, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Honda Landa PG  3500 PSI Pressure Washer Logo
238 people viewed this question
Top Honda Garden Experts
JOHN LAPIER
Marvin
Marvin
Tim Venetis
Are you a Honda Garden Expert? Answer questions, earn points and help others
