Pressing this button stops operation of other buttons.
"Locking" or "Un-Locking" is repeated whenever pressing the CHILD LOCK button. (For "Locking" or "Un-.Locking" press the "CHILD LOCK" button for 3 secs.)
When 'CHILD LOCK' is activated, pressing the other buttons would not work.
SOURCE: LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
SOURCE: lg washer model no wd
How to get the door open:
Thread a shoelace between the door and the front of the machine from the top, over the latch on the middle right and to the bottom. Pull both ends of the shoelace towards the hinge on the left and this will manually pull open the latch with NO DAMAGE. Once open you can access the screws to remove the mechanism and simply buy a replacement.
LG, bloody hopeless support and no simple way to rectify this problem in the manual when it's so easy once you know.
SOURCE: LG "WM12336FD" washing machine is displaying ,CL,
I cannot find that model number in any of my LG data.
There is a button on the control panel that will say Child Lock. That button will have to pushed and held down until you hear the chime.
SOURCE: I have an LG 3431H
Please be advised that the Child Lock function works only when the machine is in operation to prevent the settings from being altered. You should select a cycle, press start, and then hold the Delay Wash button for 3 seconds or until "Child Lock" is displayed before your cute little angel can play with the buttons and listen to the chimes.
You
don't have to accept or reject this post in order to add comment or
information. But accepting the solution
should you find it helpful and/or informative will not stop you from
posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
SOURCE: Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
