La Crosse Radio Controlled Atomic Clock Logo
C
Cher Hager Posted on Aug 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dropped my La Crosse clock (model WT 3128U) and now the hands just keep spinning. The hour hand is out of alignment in that when the minute hand is pointing at 6 the hour hand is between numbers.
Lawrence Oravetz
Level 3:
  • Master 10,558 Answers
  • Posted on Aug 23, 2016
Lawrence Oravetz
Master
Level 3:
Answers
10558
Questions
Helped
2697637
Points
29284
There is a nut on the shaft that holds the hands. It has loosened. You will have to disassemble the whole clock out of the case to access that nut
My La Crosse Radio Controller clock will not set itself. I have tried setting the time manually but it always advances by approximately 1/2 hour after the manual set. Why?
I have the same problem with my 16" analog La Crosse wall clock - it was adding 30 minutes to the time every time I set it manually because, even in manual mode, it will continue to search for the signal. Mine is the WT-3161BL with blue dial. This series of clock, which are still being sold with a black and a white dial, have only mediocre reviews on Amazon. Users report they are unreliable or reliable for only a couple of years before they become incapable of keeping time. Others have received their radio-controlled clocks - as I did - with the hands disconnected (because they're flimsy). They are very nice looking (with a stainless bezel) but quality control, not failure to understand the directions, is the greater issue.
I am responding to this post even though it is old because these clocks are still being sold - and not cheaply, in most cases, either. It would be nice if someone could PUBLISH the La Crosse instructions for re-calibrating these clocks. Why? Because from my own attempts to repair this clock I think the issue is that the hands, especially if they become misaligned or fall off in shipping and are subsequently reattached, are not in sync with what the circuit board is configured to "understand" as the 12, 4, and 8 o'clock positions. What this means is that when you select your time zone it may not, in fact, advance to one of the above-indicated times and await the signal. It may advance in a seemingly random fashion. It's not random rather the hands are not aligned with what the circuitry expects to be the 12, 4 and 8 o'clock position. If this is the case no matter what time zone you select or how good your radio reception it will never "catch" the correct time.
I have seen references in some of the Amazon reviews for those who obtained warranty service that La Crosse Technologies "calibrates" it and then sends it back. If I had to guess, calibration of a radio-controlled (analog!) clock involves aligning the hands to the position the circuitry "expects" to be the default (factory) preset. If that is correct, pushing the Time Zone button will allow it to advance the correct number of revolutions. If the hands are not in the factory defaults due to shipping damage or a defect with the assembly, it will continue to set itself incorrectly.
What is frustrating about La Crosse Technology radio control analog clock design is that "Manual Set" continues, nonetheless, to engage the atomic time signal. So even if you compensate by setting the time manually it will, as it states in the user manual, continue to "search". When it thinks it receives a signal it will reset the time, if only partially. This accounts for why, when the radio signal is not strong enough, that these clocks cannot seem to "keep time". It also accounts for why, when they are assembled incorrectly or otherwise damaged (or repaired by re-attaching the hands) that it still cannot keep time.
If La Crosse would simply design their analog wall clocks so that Manual Set DOES NOT continue to search for the atomic time radio signal it would FIX a lot of the issues encountered by owners who A) received a damaged or defective radio-controlled wall clock, and B) those who do not have good atomic signal strength in their location but for which the clock continues to attempt to make use of an intermittent (incomplete) signal. Alas, this is not how La Crosse Technologies designs these analog clocks to function in Manual Set mode, so when the signal is too weak or the hands are misaligned it will continue to try to reset itself but inevitably to the WRONG TIME. (My suggestion to the manufacturer is that they design these clocks to at least have the option to go on working correctly in Manual time set mode, as opposed to having one linked to the other in such a way that when the Radio Control fails the Manual set options also go awry.) Alas, the only real solution that I know of, short of someone obtaining La Crosse Technologies factory calibration instructions, is to DIY replace the radio-controlled quartz module with an aftermarket (non-radio) mechanism. Otherwise, a good percentage of these clocks that did not survive shipping or were not assembled well to begin with will not hold the time.
How do I change to daylight saving time?
Once the battery is installed the clock will begin searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each even numbered hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
What I would do, take the clock outside, it might not be getting a signal inside your house.
http://www.manualslib.com/manual/91008/La-Crosse-Technology-Wt-3181pl.html
2answers
How to set a Model:WT-8005 atomic cllock
download the manual from here: http://www.manualslib.com/manual/533191/La-Crosse-Technology-Wt-8005u.html
2answers
I have a WT-8005U digital wall clock. Bought 5/27/14. It will advance the hour by 2 hours or will advance the day by a day. What do I do to keep this from happening?
I do not have the same clock, but I assume the atomic receiver is the same. I found my clock went berserk if it was anywhere near anything else electronic. I had it on a dresser that was sharing space with my wireless printer. Once I relocated the printer, the clock went back to normal. You may have a different issue, but maybe check that nothing is around that would cause interference.
Need to set time for daylight savings time
You can go to the LaCrosse web site for the answers for your clock
Can you maually adjust the hour hand on the la crosse WT-3161BL IT'S SLIGHTY OFF
Unfortunately the only way I know of synchronizing the hands is to remove the glass. I am assuming your clock has a plastic glass which is held in by 3 knibs which protrude into the case.
Examine the edge of the glass and locate one of the knibs, with a small screwdriver gently but firmly push this knib in and pull the glass up to release it. Once out you can position all the hands at exactly 12 o'clock by pushing them gently (don't take them off). Replace the glass and your done!
www.serendipity-gifts.co.uk)
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
My LaCrosse radio-controlled WT 3144 clock is ticking very fast! The minute hand takes 8 sconds to make 1 complete rotation. The second hand ticks in place every second. During this moment the minute hand...
I'd say you have a lemon.
Manual:
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
For warranty work, technical support, or information contact:
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail
[email protected]
(warranty work)
[email protected]
(information on other products)
Website
http://www.lacrossetechnology.com/
La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Top La Crosse Home Experts
John
John
Are you a La Crosse Home Expert? Answer questions, earn points and help others
