Bought niece used fav 4. ran great for me during test drive, and a few trips. She picked up and drove home (30 miles-stop and go frwy. traffic),at second intersection it shuddered to a stop. then stalled, but restarted. Any advice besides cleaning intake valve/carb?
Start with the throttle body. I use brake clean and a toothbrush. Clean the plate and were it sits. Wouldn't hurt to spray down the MAF sensor, if it has one. Once you do it, it will take a few seconds to start. Once started, rev it up and spray inside the throttle. Keep it running. Most times this is a $4 fix.
SOURCE: 1999 chrysler 300m stalls when coming to stop and low power
Change the Cam Position Sensor.. It done the same thing on mine. The sensor runs about
40. to 60.00 at most parts stores Your gonna have to take off the upper intake or plenum to
get access to it. Top of the engine right side, you'll see it
SOURCE: 91 automatic Cavalier stalls after stopping
It sounds like the torque converter clutch. Just unplug it. It is the square 4 pin plug on the front of the transmission. Once it is unplugged and you get it unlocked, it will be fine. Just leave it unplugged, it won't hurt anything.
SOURCE: 2003 cartier 4.6L 120K miles. Rough idle, at idle only.
has anyone checked for a vacum leak? a vacum leak will cause rough idle at idle. check the lines from the pcv valve.
SOURCE: bmw 325i 2003 stall
Sounds like you have a small bit of dirt or grit in the fuel system when accelerating it is drawn with enough force to cut off the fuel supply then is released when engine at Idle.
1 run liquid fuel line/injector cleaner in 1 tank
2 check fuel lines for debris
3 change fuel filters
4 have fuel tank flushed
here is trouble shooting order less expense to greater.
SOURCE: 2003 Nissan Altima stalls at intersections/ stops
2002 nissan altima, accelerator , gauges, and power steering stops working. Engine continues to run and radio is working. Pull over and stop, then restart car and it runs fine for a while??
