Televison & Video Logo
Don Box Posted on Aug 20, 2016
I have an apex uk1a remote need remote code for apex pd 510 portable dvd/cd mp3 player
Three digit remote code for portable dvd/cd mp3 player #pd510 to program apex remote #uk1a
5 Related Answers
Anonymous
  • Posted on May 01, 2007
SOURCE: Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Anonymous
  • 111 Answers
  • Posted on Nov 16, 2007
SOURCE: Need a code for APex AD1115 DVD Player
if this remote uses 3 digit codes, try the following: 214, 215, 216, 401
if it is 4 digit, try these: 0386 0390 0391 0392 0424 0430 0436 0439 0445 0457 0459 0938 0913 0401 0949
cyberman2020
  • Posted on Jun 17, 2008
SOURCE: I am in need of the code for an Emerson DVD player
Emerson....................................1004, 1006, 1012, 1026, 1029, 1030, 1033, 1035, 1038,
Emerson................................1046, 1047, 1048, 1049, 1073, 1123, 1162, 1171, 1177, 1179, 1191
Quickfx PC Repair
  • 846 Answers
  • Posted on May 20, 2009
SOURCE: need remote control for my Apex Digital DVD player (model 1110W)
DVD remotes typically have 2 sets of up and down arrows for such things. Make sure the remote you purchase is meant for dvd players.
There really isn't anywhere to search for what remote would work perfect for you other than some very costly ones. So I can't really point you in the direction of a make or model.
You can also Email Apex Support and ask them for a replacment remote. It will cost you but no more than a normal remote and its made for your dvd player.
Thank you for stopping by Fixya!
Anonymous
  • Posted on May 04, 2010
SOURCE: missing portable dvd player remote. need code
In the book with the new remote will be all the codes for a bunch of different brands. Try all the codes under your brands selection. If non of them work, atleast you tried. You can always return the remote.
Need TV and DVD codes
0408 0421 0469 0654 0767. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
1helpful
Need codes for remote model number uk1a if it will work for converter box digical stream model number dtx9950
Your remote is only able to control TVs and DVD players. It will not control your DTV Converter Box.
Here is the remote (Apex UK1A) manual:
http://remotes.com/remotes/documents/Apex/UK1A.pdf
Here is your DTV Converter Box (Digital Stream DTX9950) manual:
http://cbsdallas.files.wordpress.com/2011/01/radio-shack-digitalstream-dtx9950.pdf
Need remote code for Apex AD-1201 DVD player w/Comcast universal remote (red OK button, black Comcast letters)
I don't have the original control remote for Apex Ad-1201 DVD player. I would like to use my Universal Remotes: Radio-shack USA "flag" 4-IN-ONE Remote and / or RCA 312W three component remote. I got the codes from the manuals but my DVD player doesn't work or turn off (only ejecting; open and close) with pause button. Could I get a possible code (s) for these Universal Remotes?
Not working dvd player
SERVO MOTOR will need to be replaced! Thats about all the info I can give you based on what you just typed on your problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Replace DVD remote
Check this eBay auction for the remote:
http://cgi.ebay.com/Apex-Digital-AD-1225-DVD-Player_W0QQitemZ250397256142
Note, it comes with the DVD player free.
It's only $15.
1helpful
Portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
