Hello mward05,
This is going to cost you about $35.00 in parts and about $30.00 - $60.00 per hour labor, however it depends on if it's just the convergence Correction modules and bias components or if the convergence transformers are involved. I would suggest taking the set to a repair shop and getting an estimate as a possible guide about what could be wrong. If you do not have a background in electronics, I would suggest not only the estmate, but letting the shop do the job.
Now lets discuss what is going to happen:
The shop will tell you that they need to replace the deflection board. You will have to tell then that you believe that the only problem are the convergence modules, and biasing resistors, and that you want them to explore that option first.
If they refuse take your set elsewhere, because they are not doing business the right way. I believe that this (bad convergence modules and bias circuitry) is your only problem.
I hope this helps,
Shuttle83
