SOURCE: Wiring Diagram
You can find it here; www.eclipse-web.com/download/manual/avn7000_e/installation/pdf/7000ie99.pdf Best of Luck.
SOURCE: 16 pin innerconnecting cable
i just went through that same problem, with the pins disengaging from the clip itself. if you reuse the same plug, it might come out again when its installed. my solution is just to get a new wire harness. i got my's for less then 20 bucks shipped to me.
SOURCE: Kenwood KVT 617dvd fried
the 8 pin harness is model # E30-6475-15
it is $21.69 +shipping . you can order it through M&M Car Audio
574-258-1107
or shoot them an email [email protected]
SOURCE: My eclipse avn 7000 won't calculate a route with
try this:
• After it says “CALL 800” on screen
• Press and hold MAP and AV buttons at the same time
• While holding MAP and AV buttons, Press the
MENU button 5 times continuously
• Screen will show up with 6 digit security code
• Enter Unlock Code by using touch screen
• After entering the unlock code press ENTER on
screen
SOURCE: How do I bypass the emergency brake on my Eclipse AVN 7000
You will have to connect the brake wire which is pink to the the ground wire.
