Re: LG Electric Dehumidifier Model# LRA24 not working -...
Heating up ? are u saying the fans not running (there are two fans inside) id look into why the fans aren't running , only one the speed is adjustable the other is not it runs solid speed all the time
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Hi, There can be many reasons why a dehumidifier willnot work or collect water.
A dehumidifier is a 'de-tuned' air conditioner. Its job is to remove some of the heat from the air, causing a temperature differential which in turn should make the warm air give up some of its moisture ... just like a AC unit.
To understand the operation, you must accept that you cannot cool anything ... you must remove the heat from it. The heat (energy) must go somewhere ... in the case of a dehumidifier, it goes back into the room. Oh yes, also contributing to the heat is the electric components you are running ... the control boards, the compressor and the fan ... all use power and thus, give off heat.
Should there be heat coming out of the unit? ... yes, if it is running. Don't get mad ... these are things you probably learned in 6th grade science class - relative humidity - heat differential - properties of energy - etc.
Hi, Dehumidifiers freezing up can be causes by a few different problems. Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Additional heat from a dehumidifier should only be the electrical heat generated from the compressor. This is due to the fact that the cooling coil and condenser coil (hot bit) are normally located next to each other with a common airflow so the heat generated should be minimal. Hope this helps.
