Question about Apple iPad (16 GB) WiFi Tablet PC
How do you connect the iPad to iTunes when it won't turn on?
Original question, my iPad is stuck in sleep mode and won't turn on.
Posted by stephen hanna on
3 Related Answers
adamlcw
  • 53 Answers
SOURCE: iPad USB problems
http://www.iskysoft.com/apple-ipad/connect-ipad-to-itunes.html
this is so workfu!!!
tablette pc
lecteur ebook
Posted on Feb 23, 2012
adamlcw
  • 53 Answers
SOURCE: Windows iTunes sometimes won't recognize my iPad when connected via USB
http://www.ehow.com/how_4661194_program-hyundai-keyless-remote.html
this may help you!
netbook 10 pouces
tablette pc
peggyw1
  • 6 Answers
SOURCE: how can i get my ipad 2 out of recovery mode
I assume you did reboot. After that I would try to update again.
:) Hope this works for you.
Posted on Oct 01, 2014
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
After charging my IPAD says IPAD is disabled and underneath it says connect to iTunes. what do I do?
Try putting it into DFU mode which is
-hold sleep/wake and home button untill it turns off
-let go of sleep/wake button still hold home button for about 10 seconds
-plug it up to iitunes
-and it should be there
Dec 30, 2015 | Apple iPad Air 9.7" 32 GB Wi-Fi Space Gray...
How can I delete my data from an iPad 2 whose display is black & unreadable?
Hi David,
I think this will help you please refer to below steps:
  1. Make sure the iPad battery is charged above 20% ( we would recommend at least 40 - 50 %). If you are not sure charge you tablet for at least 30 -40 minutes.
  2. Make sure iTunes is not running on your computer but is ready to be run.
  3. Temporally disable firewalls and other security software to prevent interference with iTunes.
  4. Make sure your tablet is disconnected from the dock or USB data cable that equips the gadget . Nevertheless USB cable must be plugged into your PC or MAC.
  5. Make sure your PC or MAC is awake and its screen saver is turned off.
  6. Simultaneously press and hold down the Wake/Sleep button and the Home button and wait until "slide to power off" screen appears. Don't do anything after its appearing, just keep holding Wake/Sleep and Home buttons until Apple tablet will power off.
  7. Release the Wake/Sleep button once Apple tablet is off , but continue to hold the Home button
  8. Holding the home button, connect the USB data cable to iPad. When you reconnect the USB cable, tablet should power on and you should see a message on your PC/MAC display saying that iTunes has detected an iPad in Recovery Mode
  9. After you detected this message, release the home button and press OK on iTunes pop-up to confirm the restore option.
  10. Do not touch iconic tablet and you computer while iTunes downloads and installs the fresh copy of firmware on your iPad. You will be notified by iTunes when iPad is successfully restored, but... in a while, you will get an message saying that the iPad isn't recognized. Don't panic. This is because all user content on iPad including activation status was erased during restoration.
  11. Disconnect iPad from iTunes ,unplug from computer and turn off.
  12. Turn iPad on and using iTunes activate it on any computer you have. Apple currently allows up to 5 computers to be authorized for each iPad.
Aug 12, 2014 | Apple iPad Tablet (32GB, Wi-Fi)
How to reset apple ipad
Hi Anonymous,
I think this may help you,
Aug 11, 2014 | Apple iPad Tablets & eReaders
How do I reset my ipad
Hi Anonymous please follow these steps:
Aug 08, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My ipad shows a picture of the itunes icon with the plug in going to it. What do i do?
That icon is telling you that you must set up your iPad with iTunes or update iTunes on your computer
Mar 15, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Feb 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
IPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Jul 16, 2012 | Apple iPad Tablets & eReaders
I am having problem with ipad 1. Its original IOS is 4.2.1 . Its jail broken with grenpois0n. yesterday i installed some source from cydia ( http://sinfuliphonerepo.com etc ) and secondly i tried to...
Apple iPad recovery mode
With the ipad completely powered off (not sleeping) press and hold the home button, then onnect the USB to the computer. Continue holding until you see "connect to itunes" then release the button.
Open up itunes to see recovery mode.
Follow the instructions it presents.
Mar 17, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad (16 GB) WiFi Tablet PC Logo
223 people viewed this question
Top Apple Tablets & eReaders Experts
John mullen
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
