Garmin nuvi 1350 Car GPS Receiver Logo
P
Patricia Faith Posted on Aug 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to update my garmin Nuvi 1350 with maps and can't seem to get it fixed. It is registered from mnay years ago. it is trying to power up now.
I haven't used it for a long time. Now I need it for trael. need to update with new maps
richie46
Level 3:
Top Expert:
  • Garmin Master 12,962 Answers
  • Posted on Aug 17, 2016
richie46
Garmin Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946090
Points
58151
Your battery could have gone bad. Replace it and try anew.
Existing battery might not even be taking a charge after all those years - they do wear out and need replacement.
1helpful
Garmin nuvi 1350 map cannot update
may have to download plugin, garmin communicator off my.garmin.com
tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 • GPS
tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
1helpful
How can I update lifetime maps to 1350
Contact Garmin directly---I have seen this many times on several brands, it means they are available but may not end up being free.
4helpful
tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
tip
I hope that helps.
2answers
I have a 1350LMT Garmin that I want to register for free map updates. Mine has free map updates for as long as I own it. Thanks.
You will need to go to Garmins Official website the link to the site is here either click on the link or copy and paste it into your web browser:
www.garmin.com
Look at the top right hand corner of that page where it says My Garmin click on that and create a new user account from there you can do your map updates or whatever you would like.
I hope this helps you out if it did please leave a Yes I was helped. Thank you.
Garmin Nuvi 350 can't see maps after update
Did you contact Garmin tech support? They are pretty good at it.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
