This sounds as though you have a bad lamp my friend... try replacing it. DLP Twon 039 turn on blinking green lamp light then shuts dow Forums CNET
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
SOURCE: WILL NOT POWER ON, STANDBY, LED, TIMER LIGHTS ARE BLINKING.
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
SOURCE: my tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
SOURCE: Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
SOURCE: I have a Sony KDS-R50XBR1
Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen A2 slightly.
This is a Samsung brand.
I dont think this TV has a lamp Samsung website says I cannot replace myself
