Question about Clymer Mercury/Mariner 2.5-60 HP Two-Stroke Outboards Includes Jet Drive Models 1994-1997
What oil fuel ratio is Mariner 5 hp model 6E3 6 11913 3
Serial no 11914 3 Engine has only got remote fuel tank. Need to know if fuel/ oil mix is 50:1 or 100:1
Posted by Irene Delany on
What is the gas to oil ratio for a Homelite backpack blower model # UT08111A
50:1
consider using stihl 50:1 oil as it is made to run in any 2 stroke engine at any ratio that way you only need one fuel tank correctly mixed for all 2 stroke operations
Jun 25, 2017 | Homelite Garden
I have an Evinrude 7.5hp outboard motor.Mod# 8RC1A SN# 0178194. What Year of manufd? How to mix fuel & what octane fuel to use & what oil to use? Help me go fishing, thanks.
91 octane rating ( no e-mix fuels ) and proper outboard oil ( not normal engine oil)
outboard oil has a property that allows the oil residue to stick to the metal bits and helps prevent rust
e-mix fuels absorb moisture and and rusts out steel tanks , destroys rubber components and corrodes aluminium components
the model you have is not listed on any 7.5 hp engine from 1950 to 1958
model number starts at 4434 to 7512 to 7525 in 1958
for a better answer , talk with an evinrude service center who should have a chart listing your motor
units with oil injection are 50: 1 ratio and others are 6 gallons to 1 pint of oil which is around 45:1
I would seek advice from an evinrude service center for the correct fuel to oil ratio for your engine
to mix the fuel , put the oil in first then the flow from the bowser will effectively mix it up to start with
then fit the cap on the tank and shake it up yourself
Apr 20, 2017 | Boating
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
I need to know a fuel oil ratio.
Regardless of what the manual says once adjusted your saw will perform better with this mix.
Do you need bar oil? Available at any Hardware or Home Center.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Dec 27, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What is the fuel/oil mix ration for a 345 Husqvarna Chainsaw?
Page 19 of a 2007 Operator's Manual 50:1
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
Lou
Nov 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the ratio of oil and gas mixture for husqvarna 460 rancher
Find an Operators and an IPL here:
HusqvarnaUSA.com
06 1500198
Fuel ratio 50:1 = 1gal premium/2.6oz quality 2-cycle engine oil
Fuel/Oil Mixture
Lou
Nov 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I have an McCulloch model 60013414 serial number 11-166293. i need to know the fuel mixture and would like to get a manual for it.
Fuel/Oil mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) ears 50:1 (Stihl 2.6oz/1gal)
  2. Today most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Mc manuals are hard; current IPLs can be found here:
http://www.ordertree.com/ModelInfo.asp
Yours is far from current. You might try 1-800-521-8559 GL
Lou
Sep 12, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What is the proper fuel mixture for a husqvarna chain saw ?
The Correct Fuel Mixture Ratio
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils. I once used an old chainsaw probably from the 1960s, that had a sticker on it that said to use a 25 to 1 fuel/oil ratio, but that would have been using two stroke oils of the time period the chainsaw was manufactured. In that chainsaw I used 50 to 1 ratio with no problems. Today's two stroke oils compared to yesteryears are more efficient at lubricating. It is like comparing today's synthetic motor oil to motor oils of decades ago. All the equipment I use in landscaping, anything from a weed eater, leaf blower, chainsaw, hedge trimmer, use 50 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 liter fuel can and use it in all of the equipment for my customers and for my landscaping. To calculate the ratio is simple. For instance , if you have 1 gallon of fuel it is best to break it down into smaller units, like ounces. One gallon = 128 oz. You then divide this amount by the ratio of the mixture which is 50 to 1 (50 parts fuel, 1 part oil). So therefore 128 oz of divided by 50 = 2.56 oz (you would just measure out 2.5 oz ) of two stroke oil. If using metric, say a 5L gas can, you would break this down to smaller units, which would be milliliters. 5L = 5000 ml. 5000 ml of fuel divided by 50 = 100 ml of two stoke oil.
Jul 25, 2009 | Garden
Clymer Mercury/Mariner 2.5-60 HP Two-Stroke Outboards Includes Jet Drive Models 1994-1997 Logo
285 people viewed this question
Top Clymer Boating Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a Clymer Boating Expert? Answer questions, earn points and help others
