The F02 error code on a Whirlpool washer indicates that the control detects a long drain time. This can be caused by excessive suds in the tub, a restriction or clog in the drain system or by a number of other component failures.
If the Whirlpool washer did not drain, check for excessive suds in the tub. After the suds dissipate, you can normally run a rinse/drain and spin cycle. Causes for excessive suds include not using HE (High Efficiency) detergent or using too much detergent (even if it is HE type).
If the washer will not drain and you do not detect excessive suds, you could have a clog in the drain system. Check the drain hose and the washer drain. You may need to manually unlock the washer door and then pull the large item filter on the pump to check for a clog. To manually unlock the washer door, Always saftey
unplug the washer ,to disconnect electrical power and remove the bottom front service panel as shown in the top of the image below. Carefully reach up along the inside of the front panel and pull down on the tab that is under the door lock mechanism until it clicks. This will unlock the washer door. Open the door and manually drain the water out of the washer with a wet/dry shop vacuum. Once the washer is drained, arrange some towels to catch residual water that will drain out and remove the large item filter as shown in the image below. Check for a clog or restriction that could be preventing the washer from draining properly.
If you find no clog or restriction in the drain system, you may have a bad drain pump that needs to be replaced. A problem with the electronic control board could also prevent the washer from draining.
If the washer is draining properly but you are getting this code, you likely have a problem with the water level pressure switch or the control board.
SOURCE: error code f02
the f 02 means you have a long drain issue press pause/cancel twice to clear the display check drain hose make sure it isnt plugged or kinked check electrical connections at the pump make sure the pump is running check drain filter for foreign objects if the above does not correct the problem replace the pump
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
