Water Heaters Logo
Simon Cates Posted on Aug 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manaul for 16h bosch hot water system
TF 400_8GNG serial NO593712
Marvin
Level 3:
Top Expert:
  • Bosch Master 85,242 Answers
  • Posted on Aug 15, 2016
Marvin
Bosch Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056555
Points
266281
2answers
Bosch 16h hydro
Check or replace diaphragm in the water section also clean the filter fitted at the inlet
The water goes cold after 40sec, have to turn water off and on to get hot water again. Not sure if this is the right model but it looks the same and doesnt have any electricity, 16H natural gas. regards...
Before calling service technician, open following link for Bosch troubleshooting resources
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
The model and serial number are usually located on label on side or front of unit.
Link above might have your manual where you can read advisories and required maintenance.
If you are not getting error code, then problem could be plumbing related, but this is a shot in the dark, and one of many places to start troubleshooting.
http://waterheatertimer.org/Crossover.html
Error codes are starting points, and a problem on one tankless can have entirely different cause and solution than same error code on another tankless.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Hi, My Aunty and Uncle have a Bosch Hydropwer 16H at there holiday house. About a month ago the heater would not produce a spark, they got a plumber out to have a look at the heater. He said it was the...
No, I do not know.
Open following link for Bosch troubleshooting resources.
Tankless require yearly maintenance as covered in manual. They require correct venting, gas pressure and/or electric current, they require specific incoming air quality, incoming water pressure and flow, and can stop working with basic electric problems, plumbing problems due to check valve or sediment blockage in line, or single-handled faucet crossover, and the myriad of sensors and parts each work together in a specific pattern that can be interrupted by any small or large failure, or by multiple half-failures. As a general rule, repairs are not do-it-yourself, and each part has an installation protocol. But it's supposed to last 20 years, while the maintenance, parts and service will exceed the expected 1-8$ per month savings.
Solve problem for 317$ at Lowes:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Do yearly maintenance, and this too will last 20 years with cheaper parts and cheaper overall cost, since all costs are energy.
TF-250 Boschs water heater is not producing any hot water. Pilot light is on but the ignition for the burners will not work. Is there a simple solution to this problem without replacing any parts?
I don't know. Tankless problem can be internal and external factors, or combination of factors, and vary by model, and brand.
For example low gas pressure, or gas valve partially closed (gas handle should be parallel to gas line), gas line should be 3/4", venting could be issue, or failed sensor, or gas control, or circuit board.
Below are Bosch resources.
Bosch website is model for helpfulness and easy navigation.
BOSCH:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Hi I have a bosch instananeous hot water heater 16H, it is about four years old. Since quite early in its life the hot water flow has become less and less. now when i turn the hot on full it takes...
1) You might have a simple liming problem, requiring deliming by qualified service technician.
If you want to do-it-yourself, Utube search: de-lime tankless water heater
2) Usually the warranty requires yearly, and periodic maintenance like a new car:
Maintenance protocol requires yearly de-liming.
Tankless cannot be exposed to water exceeding 11 grains hardness, and require softener and filter.
3) Look up your manual on following link and read entire thing to shake off promotion-driven-perception that tankless solve all water heater worries:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
4) The promise of 'longer-life than tank heater' is not supported by actual product warranty.
Check your manual for warranty.
5) Since all costs are energy, tankless can fall short of energy-saving claims.
2helpful
2answers
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
26helpful
3answers
Bosch gas hot water system won't turn on
i have a bosch 16h hydroflow hot water system that will not ignite.
No hot water
If the pilot light stays on, the thermocouple and pilot flame are good. If you turn the control to "on" and turn up the thermostatic control knob to call for heating and get nothing else then the control (gas valve, thermostatic control) is bad. The control can be replaced - they are mostly generic except for gas type - but they are not cheap and if the control is bad the tank is probably not far behind (changing the control could cause it to leak). Unless the water heater is less than 3-5 years old, replace the whole thing!
Please rate my answer!
I have a 2nd hand Bosch HydroPower LPG hot water system and am trying to find a manual. do you have one or is it pretty straighforwward in terms of installation? Mike
I have just dug my manual out (16H) because mine is faulty. email me and I will photocopy it at work this week and email it back to you.
Installation should be pretty straightforward and the manual's not that in depth. There are however some sections on adjusting the gas and the like that you might want to read over.
mchankey at gmail.com
regards
Mark
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
