Question about Dyson AM05 Hot Cool Fan Heater
AM05 fan is stuck on cool setting 10 and will not turn down
Cool setting defaults to maximum (10) and will not turn down either on the machine or with the remote control. Have tried turning off and leaving for a while but no joy.
Posted by Shirley Sachs on
1helpful
2answers
Dyson AM05 heat+cool only has one fan speed in heating mode. How do I fix this?
The fan speed in the heating mode is not controllable, it varies automatically with temperature.
tip
How to clean your Dyson Hot + Cool fan heater
How to clean your Dyson Hot + Cool AM04, AM05 or AM09 fan heater.
Your machine may differ visually to the one shown in the video, but the process for cleaning it will remain the same.
IMPORTANT: Please turn off and unplug your Dyson Hot + Cool heater before cleaning it. Allow it to cool for 1-2 hours before cleaning if the heater has been in use.
We recommend using a soft, dry cloth or soft dusting brush to clean the intake holes and loop amplifier. Do not use liquids, polishes or detergents to clean your Dyson Hot + Cool heater as this could cause damage not covered under guarantee.
on Nov 27, 2014 • Dyson Dryers
1helpful
Instruction manual for a AM05 Hot & Cool Fan Heater
Do you mean a Dyson AM05 hot + cool fan heater? If so, the User Guide is available on the product support page: https://www.dyson.com/support/journey/guides/300095-01.html . Scroll past the set-up and use videos and the link to troubleshooting for the AM05 to find the link to the guide. The current link to the user guide is https://www.dyson.com/content/dam/dyson/maintenance/user-guides/us/fans-and-heaters/fan-heaters/am05/dyson-fan-hot-cool-AM05-user-guide.pdf .
I hope this helps.
How do I change heat to cool?
Hi Annette, it's Jack at Dyson.
When you lower your AM05's target temperature (shown on the LED display on the front of the machine) down to 0°, the red light around the on/off switch will turn blue. This shows your machine is now running in fan-only mode, without the heating elements - suitable for use in hot weather. You can then adjust the airflow power and oscillation to suit your needs.
I hope this helps. If you need any further advice, visit www.dyson.com and click 'Support'. Or if you'd like to speak directly with our experts, you can reach the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
2answers
Why won't my fan oscillate?
There is a little arm attached to the motor that makes the fas oscillate. If it gets disconnected you will have that issue. Check the linkage.
My am05 shut off with a E 5 Display
Hi William, it's Jack at Dyson.
If your Dyson AM05 Hot + Cool heater displays an E5 error code, you should be able to reset this without difficulty. Just turn off the machine using either the remote or the control on the base, then unplug it for at least 30 seconds. Once you've done this, plug it back in and re-test. The issue should be resolved.
I you continue to see the E5 error code after trying this please get in touch directly so we can provide further assistance. If we're not able to resolve the issue over the phone with some simple troubleshooting checks, we should be able to help under your 2-year Dyson warranty.
You can reach our experts directly by calling us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
My Dyson Bladeless Fan/Heater is displaying E7 after a few minutes of running and then shuts down? It is brand new (a couple of months old) and been run about 3 times.
Hi Michelle, it's Jack at Dyson.
If your AM05 Hot + Cool heater is displaying the E7 error code, the best course of action is to contact us directly for further assistance. To diagnose the cause of the issue we would need to understand more about how the heater is being used - we should also be able to suggest a suitable resolution.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
How do you remove the base from the dyson am05
Hi there, it's Jack at Dyson.
AM05's base is secured in place by a catch - you should see this if you look at the underside of the machine. You can open the catch at the same time as rotating the base to remove it.
If you'd like one of our experts to talk you through this you're welcome to contact us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU)
1helpful
Dyson hot cool will not start
Hi Frank, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson Hot + Cool fan heater. I'm not sure from your question if your machine isn't running at all, or if it's displaying an error code. However, there are a couple of quick troubleshooting steps you can try.
If your AM05 is displaying an error code, we'd recommend unplugging it for the wall socket for 30 seconds before testing it again. This should reset the machine.
However, if your AM05's LED display lights up as normal, it may not be coming on because the thermostat's target temperature is set lower than the current ambient temperature. Try raising the target temperature degree by degree using the remote or the controls on the base. You should find it will come on once you've set it to heat the room to a higher than ambient temperature.
The Getting started guide I've attached may help, but if you'd like any additional advice from our experts you can reach us on 1-866-693-9766 (US), 0800 298 0298 (UK), 1-877-397-6622 (CA).
Dyson AM05 Hot Cool Fan Heater Logo
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
ADMIN Canada
ADMIN Canada
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
