SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
SOURCE: Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
SOURCE: Bosch Maxx WFL 2000: Conditioner Water not filling.
take out the tray. In the roof of the powder tray there is a thin strip of plastic that runs over the conditioner tray, it has 4 square holes in it, if you look closely it is secured by clips. prize them apart to flip down the piece with the 4 holes in it. you will find that it is all blocked up with black gunk, clean it out with whatever is suitable ( i used an hair grip). put things back and check it by putting the washer on a rinse, after a min it will flush out more gunk and things should work fine
SOURCE: bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
If
your washing machine will not fill, only hot or cold will fill or is
slow to fill then read these tips. I have covered many of the things
that can happen in these tips...
Washing
Machine Problems No Water
Washing
Machine Fix Washing Machine No Water
heatman101
