If you want, you can do it auto program. Press the tv and enter button at same time one the lights stop flashing press the fast forward button untill the tv turns on or off whichever the opposite currently is. Once the tv turns on or off press thr enter button. If thr tv is now on try to work the volume. If the tv is off, try tufnung the tv in with the remotd. If the tv does neither yiu passed the code and need to repeat the process. I count the times I press the ff button so if I pass the code I can go fasger until I get to around where the tv turned on or off last time. his process works for most ddvices, some tvs may require pressing the ff button several hundred times to find the correct code.
On the right side you will notice a switch showing you 2 triangles one on top and one on bottom. This is the volume switch. If you press the top triangle thr volume will increase and if you press the lower triangle the volume will decrease.
Also you can go to phone settings in the menu and increase the volume by clicking on volume control.
Cable/pulley spool gets really rusted and you can try really saturating the whole system with WD-40 but that only works about a third of the time. You will probably have to cut the cable.
actually i want tat d voice effect should b lik a surround system nd for tat i hv 2 increase d volume...by increasing the volume it gives a wonderful effect outside but m nt gettin ane vibrations inside ma car nd moreover i think thr is sm problem with vocals..shud i go 4 sm tweeters so tat sm clarity effect can b increased?..
