Cars & Trucks Logo
Micah Stelling Posted on Aug 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio problems. The rear speakers sometimes work, sometimes don't and the driver side door never works. I don't know if it is the wiring or speakers.
Kyle Steven OHare
Level 2:
Champion:
  • Cars & Trucks Expert 232 Answers
  • Posted on Aug 14, 2016
Kyle Steven OHare
Level 2:
Champion:
Answers
232
Questions
Helped
106448
Points
370
A good way to test speakers / wiring is to use a 9v battery. Unplug leads from the deck and jumper the 9v + and - to the speaker wires and see/ listen for the speaker cone to move. With this simple trick you can trace problems pretty quickly
2answers
What would cause the driver side front door speaker and the passenger side rear deck speakers not to work. When if fade the sound all the way to the front with no sound in rear and with the balance turned...
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
2answers
1999 Cherokee Sport has four speakers, two front and two rear. All speakers work except the one in the fronr driver side door. I swapped this speaker to the other side and it works fine there. ...
To eliminate wiring issue take good speaker and hook it up directly to the left front output - if it does not work then that amp is blown. Period.
1helpful
MY REAR SPEAKERS ON FOCUS 2007 HVE STOPPED WORKING DOES ANYONE KNOW WHAT FUSE COVERS THEM SO I CAN CHECK IF BLOWN ?
There is no fuse to the speakers your rear speaker wires should run under the kick plateon drivers side broken or disconnected wire or burned out channel in radio.
1helpful
Plugged in a Kenwood stereo in a 2000 tahoe. Have all power but no sound. Radio is not defective. When plugging the same stereo into a 99 express van, it works just fine. My question... What is the wiring...
Hi, your factory wire colors are below. Please let me know if you have more questions.
2000 Chevrolet Tahoe Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
I just need to know if on the back of the 1997 camaro if there are audio plugs
the stock wiring is bare bones:
1997 Chevrolet Camaro Car Stereo Wiring Schematic
Car Stereo Antenna Trigger Wire: Pink
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Brown
2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
2002 Toyota Tacoma Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Audio Front Speakers Size: 6 1/2′
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Recheck your wire connections, good luck.
Thank you for using Fixya
I need to know the color codes for the radio rear sub.
2000 Ford Expedition Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Purple
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Size: 6′ x 8′
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: 6′ x 8′
Left Rear Speaker Positive Wire (+): Light Blue/Black
Right Rear Speaker Positive Wire (+): Purple/White
1helpful
Radio harness diagram for 95 chevy tahoe....rear
check wiring on passengers side near the rear hatch speaker, the rear door speakers are run through them also. i had the same problem and it was a unplugged connector at that location
1helpful
Car Door Speakers wont work after installing new Stereo
check you Fade and Balance,sometime the ground is used for two speakers sometimes a ground is used more then once will cause your problem ........Good luck......
5helpful
2answers
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
